Look what Brown did for me today!
Alan in Little Washington (NC)
Re: Look what Brown did for me today!
David Yoho
Mine is scheduled to arrive on Wednesday!!!
I've made several of my own through the years but was always frustrated by them not being as accurate as I'd like. This little jig looks like the best solution I've seen and will solve that frustration.
Need something to cut with? *LINK*
Hoa in Alameda
I have a new set of Freud SBOX8 for sale.
Link to listing
Mine too!
Henry Higginbotham
Got mine today, too. In fact, I just came back in from the shop, where I managed to screw up the first attempt at a box by (I think) not minding my marked edge when cutting the side pieces. I can salvage it by ripping a bit off both edges; it didn't need to be any particular dimension, anyway. My blundering aside, so far it looks like a great jig.
That sure looks like ...
Mike Farinella
a gloat to me. Congrats!
If anyone has questions or problems
INCRA's Perry McDaniel did a fantastic job with instructional video and it and the manual should be your primary source of answers, but if anyone is having problems finding or understanding answers to questions about how it works or how to use it, don't hesitate to post here. I usually swing by once or twice a day and will attempt to answer them.
As some of you know the I-BOX is based on the design I licensed to INCRA. I was also closely involved in the development of the retail version.
Re: If anyone has questions or problems
Kelly Anderson
I just got the Incra e-mail today announcing it for sale and it looks like a great tool. I have a question about how much adjustment it has in setting it to the miter gauge slot.
I have an original JET Super Saw and the miter slots are 7" (inside edge) from the blade (side facing the slot), which is farther away than any other saw I have been able to measure, not by much but by enough. Since the miter slots are so far apart some table saw accessories do not work on my saw, the JET brand tenoning jig even had to have a special sub base to make it work.
So my question is will the I-Box adjust far enough to fit my Super Saw?
Thanks
Kelley,
First, if your saw has two miter slots, the I-BOX miter bar can be set to ride in either one.
When in the setup/calibrate position (with miter bar in the right slot of my right-tilt Unisaw which is farthest from the blade) the inside edge of the miter bar is about 5.5" away from the edge of the blade. It can be moved an additional 1.5" (7" total) without the miter bar alignment plate extending past the end of the IBOX fence.
So the answer is you should have no problem using an I-BOX on your Jet Super Saw. (you can actually get a little more space if the alignment plate is allow to extend past the end of the fence.)
When deciding on fence dimensions we went to TS manufacturer websites, WW and big box stores, e-mailed friends, etc. etc. then made a spreadsheet with as many make and model TS blade-miter slot distances as we could find, certainly the major brands. While it may not fit them all, the I-BOX should fit most.
Photo showing miter bar and alignment plate:
K Anderson
Thanks Alan.
I also sent a message to Incra when I got their e mail about the I-Box to ask them if it would fit. There answer was no it will not fit but you can drill and file the adjustment slot to make it bigger. That is not something that I am willing to do to make a new $160.00 tool work. This is their answer:
The guide bar mounting slots in the I-Box' body wouldn't quite reach, but it would depend on the width of the cutter (the slots are most visible in the manual in fig. 1, page2: http://www.incra.com/manuals/INCRA_IBOX_Manual_150dpi.pdf ). From where the pin plates would be zeroed against the blade, the slots are long enough to allow putting the center of the guide bar 7" from the edge of the blade.
You could elongate the slots with a Dremel tool if you needed to, or even drill a few holes further out and then grind out the material between them to create slots at the appropriate location. The body itself is more than long enough to accommodate the guide bar position that your saw would require.
Ooops, sorry I forgot about the screw slots. While the bar and alignment plate can be located to work like INCRA states, the screw slots in the bottom of the T-slots, are in fact not long enough.
The slot serves no purpose other than to provide a range of adjustability for different saws, so rather than elongate the slot, I would just drill two additional holes. If you carefully locate and drill them slightly oversize you shouldn't have any problems squaring the bar. Using a drill press it should only be about a 5 min. job.
I can understand not wanting to modify a new tool or accessory, but sometimes it is required in the rare cases when you want to use it with another machine that has a feature that could be considered an outlier- I think the Supersaw miter bar placement qualifies.
I was talking today with another owner of the same model saw who complained about the difficulty finding other accessories that can handle that blade-miter slot spacing. He had to modify his tenoning jig and a few other accessories so they would work on his saw. I experienced the same thing years ago when I owned a Shopsmith.
