NEW Shop Shot - 955
NEW Shop Shot - 955
NEW Shop Shot - 955
David Yoho
Our newest Shop Shot is available by following the link below. Like Cocobolo? You will certainly enjoy the craftsmanship of these beauties.
David Yoho
Editor - Shop Shots
NEW SHOP SHOTS!
Re: NEW Shop Shot - 955
Unsolicited navigation and suggestions
Gary Smyth
for streamlined viewing. I might be doing it wrong, but is there a way to look at "Shop Shots" all at once like a multiple image thumbnail or tile photo page and then select the photo from that block of images? The way I do it now is to look at one number, then go back, scroll down, and select the next choice, then look, and go back again to select the next, etc.
Is it possible to be able to go from one Shop Shot number (say 900, 901, 902, 903... or jump, 900, 916, 923, 904, 950....)to another without having to repeat the "Return to Index", wait, "Select", wait, procedure?
As an alternative, beside each shop shot number and brief description a postage stamp photo of what is in the larger photo. That way a quick visual could be made to find past gems.
Absolutely no intention to offend anyone, just asking.
Re: Unsolicited navigation and suggestions
David Yoho
Gary, as of now, the answer is no. Outside of the Search function, which will locate Shots by author or keywords, there is no quick way to scan the lists.
Thanks,
David
Good suggestion
I agree completely with your assessment. It's going to be a tough one to respond to, though, as we have almost a thousand shop shots in the tank already, and each one would have to have its main image thumbnailed and then coded into the index pages. That's a whole lotta work for someone.
Part of the charm of this site is that it was assembled on the fly over the past 13 1/2 years, so the styles are inconsistent and the overall organization is ripe for criticism, which is duly accepted and acknowledged.
I wish there were a way to press a button and have all our 4000+ pages of content pressed into a truly navigable format. We just have to live with what we've got until Uncle Tonoose comes through.
Gary, your point is well taken. The realities aren't likely to enable a good solution.
Should be possible in javascript
Dave Paine
Ellis,
I have also wanted to see the thumbnail image and be able to search.
It looks like the Shop Shot pages are HTML 4.01.
It seems there are a number of automated methods to convert jpg files into thumbnails.
Adding the images via javascript code should be possible
The images seem to be well organized in a folder "images2" and named consistent with the Shop Shot ID.
What program / HTML editor was used to create the Shop Shots source code?
I may be willing to volunteer to come up the HTML learning curve to help for Shop Shots.
Any assistance is appreciated
Thanks, Dave. Yes, you've got the pages pretty well figured out. I wrote the code myself years ago and we've tweaked it from time to time. There are some obstacles to coding a solution to this particular exercise, though, and I will follow up in an e-mail to discuss this further. Suffice it to say I am delighted to have whatever assistance you think you are able to offer.
Cheers,
