ADVERTISE HERE - FREE TRIAL
Short drawer slides
Short drawer slides
Short drawer slides
paul in AZ
I am building a long skinny hallway entry table with a drawer. The drawer is ~20" wide and the inside dimension of the depth for it is only 9 1/2". For a drawer that wide I would like to use side mount slides rather than bottom mount or shopmade slides.
I have not been able to find side mount slides that short.
TIA for suggestions.
Re: Short drawer slides
Re: Short drawer slides *LINK*
Yonak
Paul, check out these slides from Woodworker's Supply :
http://woodworker.com/fullpres.asp?PARTNUM=157-130&CARTID=201205126994638010--1
http://woodworker.com/8-8400-full-ext-slide-ano-mssu-156-215.asp?search=156215&searchmode=2
http://woodworker.com/fullpres.asp?PARTNUM=151-994&CARTID=201205126994638010--1
Grant Wilkinson
Lee Valley has full extension 8" slides here
http://www.leevalley.com/en/hardware/page.aspx?p=52484&cat=3,43614,43616&ap=1
No metal required
Bill Tindall
I would not consider involving hardware for a drawer of that size or application. An all wood drawer running on wooden runners will provide generations of service.
... with a slight caveat
Drawers that are wider than they are long are apt to rack annoyingly if you use wooden slides and are not extremely careful to get an exact fit -- sometimes even if you do. They are also prone to pulling out unexpectedly and dumping their contents on the floor unless you incorporate some manner of drawer stop. Metal slides aren't much to look at, but they do track well, they allow full- or over-extension, and they don't require additional stops.
Wood looks and feels better, but it's more work. Your call.
Metal-less drawers
Bill Tindall
When I am fitting drawers my test for a good fit is to push the drawer on one corner with my thumb. It will close smoothly when it fits well. This test works with drawers up to 36 wide by 20 deep, the largest I have used in chests of drawers. The drawer in the wall cabinet pictured is 28" x 9.5" deep(something close to what you need) and it passes the test easily. If the case, or in your case table, is made square and the drawer properly made and fit, it will always close smoothly, more so than with any metal hardware, even Accuride.
Re: Metal-less drawers
paul in AZ
I've kicked around several ideas on wood slides but the question of racking of a wide, not very deep drawer that Ellis raised and balkiness with moisture changes have made me lean towards ball bearings.
It would certainly be more fun to make something like side rails in a channel or an undermount. I've done center undermounts that work beautifully but in drawers half the width of the current one.
As a quick and dirty idea I see that Rockler sells premade dovetail style slides which would work either side or under mounted.
gorgeous cabinet.
Which style of wood glides did you use on it?
Construction
Bill Tindall
My drawer is constrained on its sides by the sides of the cabinet. Maple runners connect between the front and back drawer blades- all standard cabinet construction to be found in any book on case construction. In your case you would add a side piece to the runner to constrain the lateral movement of the drawer. Basically, it is a box sliding in a slightly bigger box.
I like to shellac the drawer sides and the insides of the case, then wax outside of drawer and the runners. When all is well just a nudge will send the drawer closing.
I make the drawer to exactly fit the opening. Then I hand plane the sides until it is just right- about 1/16" at most in width less than width of opening. Since the drawer is long grain there is no change in length with humidity changes.
I chickened out
paul in AZ
If this was for my own use I'd be much happier making wood slides, with no qualms about adjusting them a bit at some time should that be needed.
Many calls later I found a place that has short ball bearing slides. A bit more fiddly to install but once in there will be no callbacks.
