Concrete figurine
Concrete figurine
Concrete figurine
Doug Ridley
How would you repair this little concrete figurine?
Re: Concrete figurine
I believe you can get concrete epoxy. Contact a local landscaping supply company.
Stuart Johnson
If you have a good match between the two pieces you could drill matching holes and epoxy in a bolt. A little on the two pieces as well but don't take it to the edge. Once it's set you can mix a bit of mortar and work it into the crack. Once dry it should look good.
Drill, baby, drill !
Re: Concrete figure Options
A: Leave it the way it is. So the dude got "faced" and somebody lopped his chinwiskers. Tell people who see it that they'll grow back but it'll take a long time. Then . .
B: Go buy another one (as the guy who has the mold needs the money), and put it up next year when you can point out how well the Rogain worked.
Pete in Holland
It's a decorative piece. You don't need to drill any holes.
Clean the joint of any remaining loose grit, blow it clean & dry, then just use some slower setting epoxy (1 hour minimum). Be careful about squeeze out though. It won't come off.
My dad epoxyed the corner (8" of the protruding slab) of the front porch slab when his tractor clipped it 30 years ago. Still holding today !
Gorilla Glue
