ot real plumbing store
Jerry Gibbs
Had a leaking single lever faucet with no model #, even after I removed it from the sink. Went to a plumbing store that is a retail front end of a plumbing installation and service operation. I did not know whether my unmarked model needed a cartridge or simply o rings. The clerk was a middle aged woman with cracked hands who knew what she was doing. After spending considerable time on the computer trying to find a parts diagram, she decided to simply replace the o rings which she installed and greased. The solution worked. My cost was $1.10. Try that at a borg.
Re: ot real plumbing store
Yes, they're still out there
There's a hardware store near my parents' house - been there forever - that has the same kind of plumbing department; and the local pro plumber's supply has some staff like that: walk in with a piece of something, and they recognize it as you walk in the door.
We don't have one in our town and the #@$% box stores change models and even brands they carry fairly often so if you try to repair an older faucet forget it. I had to buy a whole new faucet when all it needed was a replacement valve.
Same is true with Appliance parts. I used to be able to go to a local parts store and get anything I needed for various Appliances. The box stores put him out of business and they don't carry hardly anything. I have to go online and order parts and hope it's the same thing I need.
Jim DeLaney, Austintown, Ohio
Re: Yes, they're still out there
Needed a replacement whole house water pressure regulator. (incoming line varies from 135~180psi!). The old regulator was 20+ years old, and had a crack in the casting.
Took a picture of the old one, in place, and took it to the local family-owned plumbing contractor/supplier. Laid the picture on the counter, and the owner's son said "Oh yeah, you need one of these." Pulled a new one off the shelf, and I was out of there in under five minutes. He even offered a couple tips regarding installation.
