Removing old pva glue
Mike Smith
My parents have asked me to repair a broken chair back from a set of chairs they received from my grandmother. The chair back failed when the back leg failed at the glue line which ran from the seat to the top of the back opening up two mortises.
Anyway, the mortises were poorly constructed and I will need to repair them. They are filled with old pva glue which everyone says must be removed before regluing.
I am doing this with a chisel and scraper which is becoming very tedious and difficult to do without damaging the joint. Is their an easier, safer method?
Re: Removing old pva glue
I've used vinegar to soften old yellow glue. I suppose you can try water. Steam also works - but there is the matter of how to direct it. I've used dry ice on epoxy to "freeze-fracture" the glue, but I haven't tried it on yellow glue. You could also try a soldering iron.
Whatever you try, protect the area around the joint.
Bill Tindall
First, it is a myth that PVA glue won't stick to itself. If PVA glue didn't stick to itself Latex paint would not stick to itself. It is common practice to precoat miter joints with PVA glue. However, it is not a good gap filling adhesive. So, if there is a blob of glue in a failed joint it means the glue was filling a gap. The glue you see is the glue that filled the gap. The thin layer of glue from a proper joint would be largely invisible. The gap needs to be fixed with shims.
Steam will promptly soften PVA glue. Steam, or hot water, is how I rid this hardened glue from undesirable places such as glue bottles, spreading spatulas, paint brushes, pants, etc. While I have not tried it, lacquer solvent might soften it or even dissolve it. Basically it is poly(vinyl acetate) and lots of solvents will dissolve PVA polymer.
White Vinegar will easily soften it so you can brush or rub it away. Unfortunately it doesn't just make it flow off, some elbow grease is required. It should get rid of enough that you can make a good glue joint and as Bill said, PVA will stick to itself. Still I try to remove all that I can. If the joint isn't a clean break and there are gaps I use a gap filling adhesive like epoxy rather than PVA.
craigd
Re: Removing old pva glue *LINK*
craigd
Is this true? Bob Smalser did some tests and found nothing sticks to old PVA glue.
I've read that there is something like a 24hr window where new PVA will cross link with old (no reference), which is why sizing works (and has for me).
Smalser glue test at the Creek
Irrelevant test
Bill Tindall
The test investigated how well marine epoxy bonded to various cured adhesives. Thus, the results have no bearing on whether any of these adhesives bond to themselves, except epoxy to epoxy.
Regular Titebind does not crosslink during cure.
craigd
Re: Irrelevant test
craigd
If you read a bit further, Bob states:
Nothing I know of in this world adheres to cured Titebond. And I've tried most of them.
Haven't tried vinegar, I usually use my Dremel tool with sanding drum to remove the worst of the old glue (all of it in round mortices), the rest is removed with chisels or rasps. Then I shim the mating part using plane shavings and hide glue, After shimming oversize, I rasp the shim to fit and install with hide glue. Hot hide glue works best for me but I have used liquid hide glue when I don't want to mix up a batch.
R Payne
The latex paint only applies to the discussion if latex paint is based on vinyl acetate. From stuff I've read (by no means exhaustive), modern latex paint is more likely based on acrylic. Not to mention there are many other differences between paint and glue.
When I have some time (next year is looking promising) I plan on testing this for myself as I've had more problem trying to re-glue where PVA has been use than any other adhesive I've used. So for now, I'm in the camp that PVA glue does not stick to PVA glue.
ron
