Advice needed : Beading a Curved Edge
Yonak
Is there a good way to mill an edge bead in the flat surface of a piece with curved edges ? Thanks.
Re: Advice needed : Beading a Curved Edge
Re: Advice needed : Beading a Curved Edge *LINK*
Bob Entwisle in NJ
Not sure about a power tool solution.
But by hand, a shop made scratch stock or Lee Valley has this Beading tool.
Bob in NJ.
http://www.leevalley.com/US/wood/page.aspx?p=32679&cat=1,230,41182
Two ways that I know of.
1. A beading bit set in a horizontal router table.
2. A draw gauge (hand tool) fit with a beading profile scraper-cutter.
The draw gauge does well on straight/even grained woods. It's more work if you've got different densities along the edge.
Make a scratch stock
John in NM
All you need is a bit of bandsaw or jig saw blade for the stock, a round file, and a block of wood. Works faster than you might think. :D
I did a long gentle curve on a shaper. Cut two curved pieces that matched the curve of the stock and set one on each side of the cutter. Then just ran the piece by. Worked great. The cut was in the face of the piece like a smile, not on the thin edge, if that makes sense.
NickinMass
I'll third the suggestion of a scratch stock. They are easiest to use on straight edges of straight grained wood, but working in shallow passes with plenty of pressure against the fence should do the trick for a curve.
Yonak
Thanks, everyone, for your responses. Unfortunately, this operation is 8 hard maple boards with long in-and-out curved edges. I was hoping there was a tool or a method I wasn't aware of. It seems ripe for some kind of Dremel-type tool and guide or something. I'll work up some sort of Plan B.
John Pappas
Not sure just what you mean by 'long in-and-out curved edges". Do the in-and-out curves make abrupt changes in direction? If so, a scratch stock might not be the best answer, but sweeping in-and-out curves could easily be done with a scratch stock.
Yonak
Thanks for your advice, John. There are a few tight curves, but no sharp corners. The worst curves are 2-1/2"r, and fairly short .. mostly sweeping curves. My main thing is that I don't think I have the stamina to hand-edge 24 lin.ft. of hard maple. I admit I have never tried a scratch stock and I could be surprised ; it may cut like butter but my gut tells me to come up with another design solution. Thanks for giving me good ideas.
Hank Knight
Beading with a scratch stock is pretty easy. 24 feet of hard maple may take a little while, but you'd probably be surprised at how quickly it goes if your cutter is sharp. Here's a little tutorial I posted here a while back. The work piece I'm beading in the example is maple.
Hank
Scratch Stock Tutorial
Yonak
Thank you for that excellent tutorial, Hank. It's definitely something to think about. Thanks for the inspiration.
