We value your privacy.
I know this has nothing to do with woodwork, but I also know there is a wide range of experience on this board. I have an auto parts cleaning tank with recirculating pump, the kind that sits on a drum. I want to get some fluid to use for cleaning some fairly greasy parts, but would like to lessen my exposure to carcinogens. I have had plenty of exposure over the years that I've worked on cars and motorcycles.
Any suggestions of effective, safe and cheap solutions to use? Extra emphasis on CHEAP!
I plumbed a p-trap into the bottom which dumped into a five gallon bucket. The submersible pump sat inside. Make sure that the pump doesn't sit directly on the bottom. The chunks and sludge will settle out like coffee grounds.
Plumb in a flexible nozzle with a half turn valve at the base and you're reading to go.
There should be very little evaporation if you seal the bucket since the p-trap is in place. You could make a cover though.
When I set it up I found an additive at the parts store that was supposed to increase the solvent action of the Stoddard solvent.
A couple of times a year I would empty the bucket through a fine filter funnel. The sludge would go in with my used oil for recycling. The rest would go back for more parts cleaning. I can't recall ever adding any mineral spirits to top-off the parts washer.
There are lots of solvents, kerosene included, that work. The catch si that they are volatile and more toxic. Still a good idea to have a pair of heavy 'rubber' gloves to use.
If I had a pile of small parts to clean I would put them in a small bucket and aim the nozzle into the bucket. Then turn it on and let it 'scrub' or soak.
A bit of Dawn or Simple Green in a spray bottle will clean off the solvent and leave it ready to paint!
For many years I used Kerosene in my parts degreasing tank. It's not as strong a solvent as the commercial solvents made for such tanks but is readily available and moderately priced. It just takes more scrubbing with a brush and rinsing to get things clean.
