Winsor chair spindle - HELP!
Dave in Bryn Mawr
Client's chair has a back spindle broken off right at the top bow. How to repair?
Thanks!
Dave in Bryn Mawr
Thanks!
Re: Winsor chair spindle - HELP!
Joseph Mulherin, Sr.
Dave, I am not an expert to offer good advice on most projects, but I have a thought which might help...
Cut off the spindle from the seat with a hacksaw blade, drill out the hole with a Fortsner bit for the correct size ,
do the same for the upper hole in the head rest, but drill the hole about an inch deeper. Take the old spindle and turn a new one on the lathe, if you have a lathe....else shave it with a good sharp spokeshave o=r a good knife..
Swab the upper and lower hole with a good glue, insert the spindle in the upper hole till the lower spindle can insert into the seat hole. Use some shavings for wedges if needed...I use toothpicks sometimes to take up soacespace for screws. Dye match the new spindle as much as you can like the original color and it should work fine.
Larry Barrett
Joe's suggestion is a good one if the chair is a fan back or crested back chair. But if it is a bow back or continuous arm (or similar) where the spindles come all the way through and are wedged, you will need to completely remove the broken spindle, carefully clean out the mortise in the seat and the hole through the bow. Make a new spindle, slide it through the top, seat in the bottom, cut off the protruding part that sticks through the top leaving a little still protruding. Remove the spindle, start a slot for the wedge, replace the spindle this time adding glue to the seat. Add the wedge to the top and refinish. Not a simple job. If a sack back chair, with an arm that the spindle goes through in addition to the top bow, I think you are out of luck.
Dave Paine
Some good replies, but we are all shooting a bit in the dark. Can you post some pictures?
Do you have a lather to try and make a replacement spindle or are you looking to salvage the broken spindle?
Lots of variables.
Re: Winsor chair spindle - HELP! *LINK*
Larry Barrett
Dave
Here is a link to the web site for Curtis Buchanan, who is an excellent traditional Windsor chair maker. In the last year or so Curtis has posted a series of videos that show the complete process for making a traditional Windsor. You can skip ahead to where he makes spindles (not on a lathe) and where he installs in a chair. Even if you want to make a spindle on a lathe, or shape from a dowel, the process will be similar.
Curtis Buchanan
Do you have the confidence to make the replacement spindles (not to mention the tools)?
What type of wood?
What type of chair? Loop back, continuous arm, sackback, fanback, comb back or what? All of these would use slightly different techniques to fix. Can you grab the spindle with padded vise grips?
I typically replace spindles by cutting the spindle. I then grab the spindle near the end and apply heat (heat gun). As the heat loosens the glue, I twist the spindle. I might use moist heat, but usually use just heat. I remove one portion, then the other.
Show pictures - you will get better answers.
George Colonel's Workshop-Havertown PA
Good Afternoon Dave,
Post a picture if you can. I've repaired several Winsors and have had to disassemble them before I could drill out broken tenons at the required angle. It is tedious, but do-able. You are welcome to use my lathe if needed.
George
Re: Winsor chair spindle - my solution
Dave in Bryn Mawr
Thanks to all for your response. Here's what Ive done.
Remove spindle. Drill out top hole in bow back. Make spindle longer at the bottom by turning a 2" long piece to correct diameter. Cut this and the bottom of the spindle at an angle to create a scarf joint. Cut off new bottom to correct length including 3/8" which goes in the top bow hole. Insert top and bottom pieces and glue (epoxy) the joint. Tape a straight piece of scrap to hold it straight. Voila!
The "Mother-of- necessity" seems to have taken hold here and you got the spindle repaired....great.
