furniture stripping question
Bill Tindall
Daughter wanted to restore her great grandmothers chine closet, ca. early 20th century, white oak with lacquer finish. Actually it is white oak and bird's eye maple, a gaudy combination that I will separate during the rebuild.
It has been awhile since I refinished anything and apparently I have never dealt with lacquer before. I am having a miserable time of it. I am using methylene chloride stripper. The problem is that the combination of stripper and lacquer results in the most intractable sticky gunk with the properties of contact cement. The resulting viscous sticky stuff adheres to the wood and defies being picked up readily by rag, or coarse steel wool. Even scraping is marginally successful.
Is there a more successful approach?
Re: furniture stripping question
I usually use abrasive pads going from coarse to fine.
For lacquer, I use lacquer thinner and a suitable retarder. I also work in a well ventilated area with an air-purifying respirator.
Carol
I send it out to a stripping shop. It doesn't cost much. The home strippers are not inexpensive and the labor ought not to be discounted, not to mention the clean up. To me, a strip shop is a bargain!
strip shop
Bill Tindall
Alas we have a place called the "Mouse's Ear" that advertises strippers but they don't seem to do the kind of work I need. There are no other strippers to be found of any variety in my area. Otherwise you are right, I have better ways to spend the time.
Norm Knoxville
Bill, I've used the non-flammable zip strip on lacquer. Small areas at a time because it does gum up some. I use a plastic scraper mostly and brass wire toothbrush for detail.
Good luck, it's a chore no one enjoys. Norm
Bob Lang
Ditto on the lacquer thinner. Think about the chemistry involved, you can scrub it off with the appropriate solvent, same way you can scrub off shellac with denatured alcohol. For some pieces of that period, a combination of lacquer thinner and alcohol works best. Get a gallon of each, start with your best guess for the ratio, experiment to get it right and forget about the stripper.
Bob Lang
Thanks JL and Bob
Bill Tindall
I thought of, then dismissed the lacquer solvent idea thinking it would evaporate too fast to be useful. I have a can of retarder(pricey stuff) and indeed it does a fine job. Smells good too. I'll go hunting for a big ketone or butyl acetate Monday and I suspect this low volatile solvent plus 5%methanol and I will be happy.
Howard Acheson
Bill, how sure are you that the original finish was/is lacquer? Lacquer was developed from some work done during WWI and only became a commercially used finish in the early to mid-1920's. If it was/is lacquer, the finish should easily come off using methylene chloride based stripper.
Do you think that there are more than one type of finish on the item?
Here is a process that may allow you to determine what finish you are dealing with.
The problem with stripping lacquer
Bill Tindall
Lets start with varnish, something I have more experience stripping. Once cured, varnish is insoluble in everything. However, it swells in a strong solvent like stripper solvents and becomes soft. Once soft it is readily scraped from a surface because it is not dissolved in the stripper solvent.
The problem with lacquer is that it dissolves in the stripper solvent, making it even more viscous and sticky than it already is. I was not exaggerating when I said the result resembled contact cement. Imagine removing a layer of contact cement from wood. Unlike the varnish case, the dissolved lacquer sticks tenaciously to the wood.
The suggestion from Bob and JL is to dissolve it in enough lacquer solvent to yield a less viscous solution that can be wiped off, more or less easily. Indeed with plenty of solvent and paper towels one can soak up the dissolved lacquer and remove it from the surface.
What I have settled on is to begin with stripper and scrape the surface after the stripper has dissolved the lacquer. I am able to scrape off about 90% of the sticky mess. The film of lacquer left can then be removed by repeated applications of lacquer solvent, soaking up the dissolved lacquer in paper towels.
The very good news is that the remaining wood surface is smooth and a nice "oak"color. I will only have to spray back on a coat or two of lacquer after replacing the bird's eye maple back with an oak back. It took a flawed sense of design to imagine that a bird's eye maple back looked appropriate in a dark quartered white oak china cabinet.
making progress
Bill Tindall
Tedious task. Rather be building some than fixing . A multitude of solvent vapors in the air. The weather was nice for this outdoor activity.
Note the panel of bird's eye maple that was in the back of this thing. I will replace it with rift cut oak.
