We value your privacy.
I've got some brass hardware I want to remove the tarnish from and coat with something to prevent, or at least slow up retarnishing. This would be on an exterior door.
I plan on buffing with buffing compound first, and am wondering about leaving a residue, what to clean that off with, and what is the best product to spray on.
but I use it on most things too. "Never-Dull" wadding. It leaves behind an itty bit of oil to protect until the next time. No further coating needed. Just rub on it evry other month or so. Easy. I think a coating scratches or gets ichy after time. Then ya' gotta strip it off. BLAH !
Polish with Brasso or other high quality polish, clean with Naptha or Acetone, spray with clear lacquer, and put in a vacuum chamber to dry and remove air bubbles. Or send it out and have it done!
I restored several of my exterior doorknobs and finished them with Staybrite. I cleaned what lacquer was left on them with lacquer thinner and elbow grease. I polished with a metal polish. Cleaned them up real good and sprayed them with Staybrite. They have held up very well for several years. I think the Staybrite is better than the factory finish (these are low grade hardware).
There are several ways to clean the polished brass. You can use strong soap and water. However, it gets tricky drying the parts without touching them which would leave some body oils on them. The easiest way to clean is lacquer thinner and paper towels. You may need a second or third cleaning until the towels show no buffing compound residue. Then still holding the piece with the clean piece of paper towel, slip a handling wire through one of the holes in the piece. I use a piece of a metal hanger that things from the laundry come on. Now you have a way of holding and moving it without touching it. Spray a coat or 2 of clear lacquer and you're all set.
Besides a jug of white vinegar, another thing I keep in my shop is a bottle of concentrated lemon juice. Both are excellent at cleaning tarnish from old brass. I've had occasions where a bit of a soak was in order before cleaning was effective.
I also use the vinegar when I need to disassemble an old joint glued with hide glue. I heat a cup of vinegar in the microwave and brush the hot liquid over the joint until it softens the glue. Water works too but I have had better results with the vinegar.
