elliptical legs
elliptical legs
elliptical legs
mikemcnerney`
I need 20 hardwood, elliptical legs, 2" x 3.5" x 30" .
Is there any manufacturers somewhere who can do this kind of thing?
Mike Mcnerney
Re: elliptical legs
That would be an easy job on a shaper
Keith Newton
All you need is a quarter of the shape. A 1"x 1-3/4" cutter will do it. You might even be able to find a router bit that size.
Re: elliptical legs
Re: elliptical legs
John McGaw
I am trying to imagine an elliptical leg and my mind is rebelling. Is the ellipse (or portion thereof) the cross-section or does it describe the curve the leg makes from top to bottom or is it something else?
Re: elliptical legs
Re: elliptical legs
Keith's suggestion is right on, if you want to make these yourself. If not, find a local custom shop that has shaper cutters that match your desired profile. For a run of 20 pieces, it probably doesn't make sense to order custom ground cutters.
If you *do* try this at home, my suggestion is to make the blanks a few inches longer than necessary and rig up infeed and outfeed tables and fence extensions that are flush with those on your router or shaper table. Clamp a stop block on the right fence (as you face it) at a distance an inch or so less than the length of the blank. This acts as a backstop when you swing the blank into the cutter, and leaves a rectangular profile at the end of the blank. Use a similar stop block on the outfeed side to stop the workpiece before the cutter takes out the back end. The rectangular ends make it easier and safer to make these cuts accurately and without the workpiece rolling when the cut is finished. It also makes it easier to make the profile in multiple passes, which is desirable, especially with dense or brittle wood that may tend to split if you take too big a bite.
Ellis Walentine, Host
Re: elliptical legs
Re: elliptical legs
John in NM
Are they elliptical in cross section only or also in vertical profile? If they are elliptical in two or three profiles, you'll need someone with either a copy carver or a good eye :D
Re: elliptical legs
Re: elliptical legs
mikemcnerney`
elliptical in crossection 2 x 3.5.
I made them once before myself on a router table but my hands are getting tired & i was hoping to get a lead to someone set up to do it?
MM
Re: elliptical legs
Much easier then...
John in NM
Just a shaper and some tooling, find a guy who has a power feed on his shaper and you're in business.
Re: elliptical legs
I've forwarded your request...
... to a buddy of mine who suggested making these pieces on his gunstock lathe. He may be contacting you, but I can't guarantee it.
