We value your privacy.
I have a split level house the living room is open to a stair well how high does the ballister need to be to prevent people from falling over? Just need to meet code. I know if it went to the ceiling some of my friends would find a way.
If you are talking about a horizontal railing around the top of an opening, the usual height is between 36 and 42 inches with most of them being closer to 36". If you are talking about a handrail down the steps the usual height is 34" vertically above the nose of the tread.
Checking with the local building officials might also be a good idea.
You do need to keep trying to reach your city inspector and ask if there is a baluster maximum spacing too. The top rail height in many locations, even for homes, are moving to the OSHA 42" to the top rail.
When my younger two kids were little I found I needed to have tinted safety glass panels installed as they could easily fit between the balusters. The panels were set a few inches about the floor.
So what did I find? They still sat with their little legs stuck under the panels and smeared slobbers on the glass panels. Glad when they grew enough they could not fit.
in this area, in the direction of more height on the railing. So, you want to know what your local building department wants, or go for the higher railing choice.
Also, responding to Galen Vetterick's comment, our local code requires that the balusters be spaced closely enough that a 4" ball can't fit between them anywhere. I made a 4" circle out of cardboard and used that to test when I did our porch.
