A55 Smoothing Plane
Tile over linoleum?
Tile over linoleum?
Tile over linoleum?
Ernie Miller Topeka
I am wanting ceramic tile installed in my Kitchen the installer says it is OK to put over top of the exhisting Linolem. However I think it would be subject to popping lose is this guy right?
Re: Tile over linoleum?
I sure wouldn't do it - I would either strip the linoleum or if raising the floor another 1/4" isn't a problem I would screw down one of the cement board underlayments made for tile, then lay it. You would then have a ridged floor to prevent tile cracking and perfect adherence.
Jason Waters
Agreed here, not a good idea in my opinion. I have seen vinyl over vinyl and would never do that either.
Jason Waters
While I certainly like the House Doctor shows and Ron Hazelton, I would like to see where this has been used for 10 years or so and how it's doing. For instance, once this is done, how about moving some large furniture or a refridgerator over the floor on a dolly. The localized stress would lead me to believe the vinyl may have enough flex to break the grout line or the the tile. I would still remove it. It might be ok for a small bath or something, but that's not that bad to strip (ie, small). This vinyl must be over wood. Because if it were over concrete, it would be easy to strip and worth it in my opinion.
No, no, no.
Galen Vetterick
The video fooled me as I figured it was going to show an adhesive set ceramic tile and more of a silicone based motar. I have owned a mobile home, travel trailer and a motor home but none were the more upscaled ones I see today that have ceramic tile in kitchens or baths. I would like to see how that is done as I know there is flex in the floors. Wonder if there is anyone here that worked in that field to say how they make that work?
