OT - String Trimmer Carb Adjust
Ralph Lipeles
My Weed Eater XT 50 string trimmer has both high and a low carburetor mixture adjust screws. Does anyone know what the initial needle adjustments should be so that I am in the ball park when I try to get it started?
Thanks in advance.
Ralph
Re: OT - String Trimmer Carb Adjust
RobCarr
Honestly, don't mess with them - if it's not running right take it to a shop that repairs them. Every time I have ever mess with carburetor's idle/speed/mixture adjustments it was usually worst then before I started... and that's with the service manual in hand to guide me! ;)
Moses Yoder
Moses Yoder
I don't know about that particualr carb, but they are usually out about 2 turns. Turn them all the way in, out 2 full turns, it should run and you can adjust them from there.
Re: About the same I always used 2 1/2 turns.
Jason Waters
If you are having weed eater problems (or any 2-cycle engine really), the first thing to do is dump the gas out (in jar for properly disposal) and refill with fresh, mixed gas, preferably ethanol-free.
That solves hard starting on mine about 90 percent of the time.
