Re: Sparky Question
Joe W
The few homes that I have worked on, we have used 2 AWG copper for 100 Amp panels. I know you are a little smaller, but, it depends on what type of wire the electrician is using. My Ugly's shows 4 AWG THHN good to 85 amp, so 2AWG would be the correct size. I assume you are using a wire something like THHN since you are going to use conduit.
Fill also matters on what type of wire. Again, using THHN, it looks like like 1 1/4 plastic PVC Sch 40 will take 5 2AWG wires. Should be OK since the ground will not be larger than probably 6AWG.
Copper wire is pretty expensive and you may want to consider aluminum instead. The short run and the increase in conductor and conduit size would probably be offset by the price of aluminum vs copper.
The electrician's price may still be based on him getting the materials. He may not be comfortable with you purchasing the materials. He may have had a bad experience with a client who wanted to get too involved in laying out a job in the past. He knows what he needs and wants, and if he shows up and you have forgotten an item or purchased the wrong item, it will cost him a lot of time. If you trust him, it may just be worth it to let him do his job and suck it up.
