Regular poly vs. wipe-on
Paul Blackwell
Is there a difference between regular polyurethane and wipe-on polyurethane? Can regular poly be wiped on? I haven't used wipe-on before, and am going to try it on the next project. Is the resulting finish comparable to brush applied poly?
Re: Regular poly vs. wipe-on
George Colonel's Workshop-Havertown PA
Good Afternoon Paul,
I don't apply poly with a brush, nor do I use it right out of the can. I make my own "wiping" poly mix using approximately 50% poly and 50% naptha and wipe on with a high grade paper towel. No bubbles, no tracks, and it dries to the touch in a couple hours, so minimal dust nibs. Of course, it takes more applications of my wiping poly to achieve the desired build and protection. Nothing wrong with wiping poly from the box store, except its more expensive to buy that way. Try mixing your own: proportions of poly and naptha don't need to be exact. I use the glug-glug method of mixing the ingredients.
George
gary peterson
make your own, I use spa varnish semi gloss, blo and mineral spirits....just finished a dresser and the finish wasn't producing a nice sheen, darn, had forgot the blo. Mix first appl equal, then mix with higher ratio of varnish to blo and spirits for subsequent coats...four to five is nice.
Re: Agree
I have both wiped on and sprayed Minwax poly with great results. Mr. Michael Dresdner advised a few years ago that it was far less expensive to mix your own and it is the same formulation. I also learned from him (he is one of the foremost finishing experts on finishing in the world), that you could use almost any petroleum solvent when thinning - I have used Naptha, paint thinner, mineral spirits, acetone, and turpentine with equal results after the drying cycle. Some of the solvents do dry faster. A slow solvent can be used to improve flow out of the surface, or conversely a fast solvent can aid in preventing runs on vertical surfaces and reduce dust nibs. A review from one of the Woodworking mags found that the Minwax Poly was as good or better than all the polys available and was in some cases far less expensive. As a result, that is the only poly I use. You can also add BLO ~ Tung oil etc to the Poly to change its characteristics - need to try on scrap first as always!
Howard Acheson
Here is something that should help. A friend of mine who was an early advocate, put it together years ago and it has worked well for many.
QUOTE
There are a number of suggested application regimens that are totally subjective. The number of coats in a given day, the % of cut on various coats, which coat to sand after, when to use the blade and a whole host of other practices are all minor differences between finishers. There are some things that I consider sacred when applying a wipe-on finish.
First, you can use any full strength oil based clear finish. Polyurethane varnish or non-poly varnish is fine.
If you are making your own wipe-on the mix is scientific - thin. I suggest 50/50 with mineral spirits because it is easier to type than any other ratio and easy to remember. Some finish formulators have jumped on the bandwagon and you can now get "wipe on" finish pre-mixed. If you use a pre-mixed, thinning is generally not necessary. But making your own is cheaper and you know what's in it.
The number of coats in a given day is not important. Important is to apply a wet coat with an applicator and merely get it on. Think of a 16 year old kid working as a busboy at Denny's you have sent over to wipe off a table. Sort of rub/swirl the the material on like you would if you were applying a paste wax. Don't attempt any straight strokes. The applicator should be wet but not soaked. The applicator can be a non-embossed paper towel shop towel, half a T-shirt sleeve or that one sock left after a load of washing. Once applied,leave it alone. The surface should not be glossy or wet looking and, if applied correctly, there should be no "brush stroke" type marks. If you have missed a spot, ignore it - you will get it on the next coat. If you try and fix a missed spot you will leave a mark in the finish.
Timing for a second coat involves the pinkie test. Touch the surface with your pinkie. If nothing comes off you are ready for another coat. If was tacky 5 minutes ago but not now, apply your next coat just as you applied the previous coat. Remember, you are wet wiping, not flooding. After applying the second coat, let it fully dry for 48 hours. Using 320 paper and a sanding block lightly sand the surface flat. Now, begin applying more coats. Do not sand between coats unless you have allowed more than 24 hours to elapse since the prior coat. The number of coats is not critical - there is no critical or right number to apply. For those who need a rule, four more coats on non-critical surfaces or six more coats on surfaces that will get abraded seems to work.
After your last coat has dried at least over night you will have boogers in the surface. You should not have marks in the surface because you ignored application flaws. You may have dust, lint and, if you live in Texas, bug legs. Use a utility knife blade at this point. Hold it between your thumb and forefinger, near the vertical, and gently scrape the surface. Gentle is the important word - no harder than you would scrape your face. If you start scraping aggressively you will leave small cut marks in the surface. After you have scraped to the baby butt stage gently abrade the surface with 320 dry paper or a gray ScotchBrite. Clean off the surface. Now, leave the area for two hours and change your clothes. Apply your last coat with a bit more care than the previous coats and walk away.
An anal person is going to have a tough time with this process. Missed spots have to be ignored. Wet wipe, don't flood. Scraping to babies butt smooth means scraping no harder than scraping a babies butt. Ignoring any of these will leave marks that are tough to get out. Getting these marks out requires some aggressive sanding to flatten out the surface and starting over.
Jim Kull
END QUOTE
Finally, It works better to use a gloss varnish for all coats except the last. The flatteners in semi-gloss and satin tend to rapidly fall out of suspension when the finish is highly thinned. If you want a non-gloss finish, use it only on the final coat or two and be sure to stir the material frequently or you will end up with cloudy streaks.
I Remember Jim Kull
Good Afternoon Howard,
What became of him? I haven't seen his name in years.
George
Re: I Remember Jim Kull
Howard Acheson
I don't know what happened to Jim Kull. I knew him when he lived in northern California and knew that he moved to the Dallas Texas area. But then he dropped out of sight. I sent him a number of e-mails to what had been his address but never got a response.
He was always someone who flew outside the flock. That's the reason a number of folks liked him.
Last thing I heard was from someone who had no direct knowledge but claimed he had passed away. Don't know it it's true.
Re: I Remember Jim Kull *LINK*
mdclor
I don't know if this is the same person or not. There were others listed, but this is the only one that is 65+ which I guessed might be correct based on the comments.
James D Kull
