ADVERTISE HERE - FREE TRIAL
Shipping brittle veneer
Howard
I need to soften some brittle veneer so that I can coil it for shipment and was considering the following formula to soften it: Four parts water, two parts glycerin, one part alcohol. Shipping time would be about 5 days.
Does anyone see any problems such as:
Mold growth, veneer taking a set during shipment etc?
Thanks
Howard
Re: Shipping brittle veneer
Howard, our old formula for flattening solution was 8 parts water to 1 part glycerine, not 4:1, but there may not be any harm in using the more concentrated solution. I never used alcohol or glue in the mixture, but I've heard all kinds of pet formulas.
Once you soak the veneer, it'll take a few days to suck most of the moisture back out with newspaper, changing paper daily and keeping some flattening pressure on the stack during the process. Then you should be good to coil it without fear of unforeseen consequences. For safety's sake you might want to alternate layers of brown paper or newsprint between the sheets of veneer.
