work photos
work photos
work photos
Joseph Mulherin, Sr.
Tried again and again to get this camera setup to send photos.....NOT HAPPENING!!!! Need someone to sit with me physically and go thru the entire processes of taking, transferring, and posting pics.
Cameras is one thing I have always had a "black thumb" with. Pics are in the camera, transferred to computer, but in trying to send them to WC it always comes back and says they are too large...I set them for the lowest setting possible on the camera. NUTS!!!
Re: work photos
Re: work photos
Carol
Joe, you want the camera to do too much work. Once the pictures are on the computer, resize them to meet WC requirements.
One step at a time, my friend.
Re: work photos
Re: work photos *LINK*
Jesse Cloud
Here's the address to download Pixresizer, a simple freeware program that does one thing only - resize pictures. I use it when I am sending a picture to the web.
There are lots of different programs that do this, but most do many more things as well. I find this one the easiest to use.
bluefive freeware picresizer
Re: work photos
Re: work photos
Thank you, Jesse, I shall try using this program. However, I made the pictures on my Nikon L24 camera, set the camera to transfer them to the computer at the 320-640 scale....but in viewing the folders and trying to send them out I found out that the pics are listed at 155KB....and WC is setup for only 100KB.
I am really getting so disgusted with having to jump thru the hoops just to send out pics of my works. Cameras are not my thing
Re: work photos
Re: work photos
I shall continue working on my rocking chairs for the family...but y0u people will probably never get to see them. The model I am trying to copy is the Sam Maloof rocking chair....you can find it on YouTube under Maloof chairs. Intend on making four of them this year. My own which is the prototype for the finished chairs is going to stay here at my home for my own use. Want to work out the construction techniques to be clear in my mi9nd before I buy some more expensive wood to make the others....maybe mahogany or walnut or oak.
Re: work photos
Re: work photos
My Kodak M340 camera takes and loads pictures from 129-243 kb.
The Nikon L24 does not go below 155kb.
Re: work photos
Re: work photos
Joe, you will not get pictures that size from your camera. You should take regular high-quality photos and then just resize them using one of the programs that people have been suggesting to you. You're making it much harder than it is.
Try pixresizer as someone suggested, or any of the other freeware resizers.
Re: work photos
Re: work photos
Chuck in Mtl.
I am using fastStone Image re-sizer however there are many other free programs as well.
Re: work photos
Re: work photos
Chuck in Mtl.
you need to get an image re-sizer otherwise nothing will work for you.
As was suggested continue to take pictures in a high resolution format but let the re-sizer do all of the the work.
1) open re-sizer.....select photo to be re-sized in the re-sizing program
2) select output format....the output must be 100kb or less...might need several tries to get this right.
3)select and upload photo to wood central
4) it should work now
go here... http://www.faststone.org/
Re: work photos
Re: work photos
Chuck in Mtl.
this photo was resized to 88kb and I added text to the photo(my name).
Re: work photos
Drive-by?
You just happened to have a picture of Easter Island around? :)
Re: work photos
Caution
Yonak
Beware when downloading this picresizer software. After downloading it I found a new tool bar in by IE and Firefox browsers and my home page had been changed in both browsers, without my permission. Plus, this morning, I found a new commercial site page came up when I first launched Firefox, after I changed my home page back to my preference yesterday.
Re: work photos
Kneale Brownson
Wouldn't that be float by?
Re: work photos
Kneale Brownson
Again, upload full-size pix to a website
Kneale Brownson
that doesn't care about how big they are. There are free ones like Photo Bucket, but you never know when those will disappear. I use P-Base, which has a small annual fee. Then you can post to WoodCentral using a link to your pix elsewhere.
Re: work photos
Re: Drive-by?
Chuck in Mtl.
yes I don't remember when I downloaded it but I have never been to Easter island personally...maybe one day.
Re: work photos
Resizing
John in NM
I use Gimp for resizing, you can simply scale the image and save it as a new name, then there's a little preview checkbox on the save screen. Check that and it will tell you how big the file will be and you can turn the image quality up or down to fit your needs.
The program is a free download, has versions for Windows as well as the others, and does a huge amount of stuff if you climb the learning curve. For scaling and sizing, there's hardly any curve at all.
And being open source, they're not trying to sell you stuff, so there will be none of the annoying nonsense that Yonak mentions below :D That's probably my favorite thing about open source software.
Re: work photos
bandsaw maintenance
The other day I was working cutting some wood for my next chair and the upper wheel started to wobble causing the saw blade to stop at times and running bad. So, today i went to the Shopsmith service
parts and ordered a new upper wheel.
Also, did some research on chairs and found a website telling me how a guy followed the Hal Taylor design and made two chairs. address: http://hubyuk12B.blogspot.com/
Think I shall follow his design because it matches my thoughts on the designs I am attempting. Have no plans, but intuitiveness and pictures will allow me to make some patterns and cut the wood properly.
Re: work photos
Re: bandsaw maintenance
correction on website mentioned ....it is hubyuk128.blogspot.com
Re: work photos
chair plans & templates
Downloaded some pictures of Hal Taylor's chair; made some scaled measurements. Bought some good thick posterboards; laid out the measurements, drew them, and cut them out ready for scribing on wood for cuttings.
Have some medical problems i have to attend to at the VA, so no work on chairs until around June.
Re: work photos
Re: work photos
I downloaded the Gimp photo processing program, went to get my pictures from the cameras and the message came back that there were no more pics to download on either camera....they are there on the drives and chips in the cameras but I do not understand how to get them out to the computer again.
Again...this is exactly why I am so disgusted with the picture taking and posting....nothing works for me!!!
Re: work photos
Re: work photos
Chuck in Mtl.
Find out where they are on your computer...probably in the pictures directory I'll bet.
Re: work photos
Re: work photos
Nope, already checked that first thing.
Am just going to take some new pictures on a different chip card on the Nikon, but the Kodak ...I don't know what to do about that one....probably just take some more different pics also.
This whole camera, posting thing has me soooo frustrated. But with Gimp program I shall try once again.
In the Navy studied and worked in Sonar, radar, navigation; studied and passed two computer programming pro0grams; had a license for medical gases in surgery piping; and many pther technical things....but this camera business has me completely fooled.
Re: work photos
Kneale Brownson
Re: work photos
Kneale Brownson
The cameras have a removable memory card. That card will go into a reader attached to the computer. That is a much simpler method of getting images into the computer.
Re: work photos
Re: work photos
Joseph Mulherun, Sr.
Kneale, I took the chip out of the Nikon camera, installed it into the printer, got message that there were no pics available to view. Guess something happened in the earlier transfer to the computer and I probably deleted them from the chip.... so no pics to show.
