Table top wax
Dave Dircksen
On the pieces I build should I put wax on the tops? I use red oak and the wife does the finishing. She uses wipe on poly. Thanks
Table top wax
Dave Dircksen
Re: Table top wax
paul in AZ
I can't think of a good reason to put wax on top of poly.
Re: Table top wax
Dave,
Wax is probable the single more fragile of finishes; it sits of the wood, attracts moisture and goes dull, shows every dish mark or alcohol spot.
Do your poly and call it a day. Since you're doing a table top in oak, if the LOYL prefers a filled-pore, piano finish, look into grain fillers as part of your finish routine.
Johnson's Wax Company pulled off one of the great marketing ploys by making zillions based on that "Good For The Wood 'Cause It's Wax" line. Wax can't actually penetrate wood fibers, but the jingle was great, and, of course, people kept buying Johnson's stuff thinking "If a little is good, more's better!"
m
Re: Yes!
Al Stokka - Cambridge, Iowa
By all means wax the tabeltop. Johnson Paste Wax is my choice.
Wax will act as a safeguard against a short-lived water droplet.
Was will reduce friction against the film finish. Think about sliding a newspaper across the finish...there is always dust (very fine abrasive) on a tabletop no matter how clean a house you keep.
Wax provides a velvety smooth surface that you'll love to run your hand over.
Cantrary to what you'll hear, you will not see fingerprints or smears on a sufce which has been properly waxed.
Al
Re: Yes!
Joe in a Cleveland suburb
"Wax provides a velvety smooth surface that you'll love to run your hand over."
Agreed. That's the biggest reason I like to put some wax on the things I make.
I admittedly am not a good finisher and it takes a long time for me to actually complete a project, but when I do and use some sort of poly, rubbed out, then a final coat of wax, I love the feeling of it. The smell too.
Re: Yes!
John McGaw
I'll agree up to a point. For furniture items I've given up on Johnson's, which I reserve for rustproofing tools. For me, Briwax is the way to go -- its finish is harder and more slippery and seems to attract dust a little less. Plus it is available in multiple colors (or colours as the can might say) which can be useful. As with any wax, achieving a thin even coat and buffing well is the key. For turning I often use my own concoction of bees and carnuba wax with natural turpentine. One thing for sure is that wood just feels better with wax on it.
Re: Yes! - agree
I also really like the appearance and feel of a wax coated surface. I often finish with lacquer (Behlen Qualalacq Spray Lacquer) using a few thin coats of gloss then finishing with a coat or two of satin - then rubbing out with Clear Briwax and 4-0 steel wool - after buffing it really feels and looks nice to me. I also have sprayed a 50/50 thinned Minwax poly and sprayed shellac, then rubbed out as above. Regardless of whether it protects or not, I like the finish obtained and will continue with this regime.
Re: Table top wax
eliot d
An important thing about applying wax, if you want to do it, is to put in on very, very thin. One of the best ways is with a brush -- like shining a shoe.
