What is? Anyone? Anyone?
Gary Smyth
I originally thought that this was a detonator but could not find a release button. The wires are six feet long and have alligator clips opposite the box end. Then I thought it might have something to do with communications - as in old crank telephones. It was found at the estate of a plumbing contractor. No markings other than "GB 90530" and underneath that is "10000". This is engraved on the top plate where the screw down connectors are.
The crank handle pushes in toward the box and rotates in either direction. It takes a bit of effort to turn it and when that happens the box has to be held down. When turned, somewhere there is a bell sound inside. I have not opened the box yet. The holes are covered with a fine mesh screen.
I'm open for suggestions and photo of another if you know.
Re: What is? Anyone? Anyone?
Army field telephone??
Re: What is?  Anyone?  Anyone? *LINK*
John McGaw
Paul was at least semi-close when the called it a field telephone. Actually it is an even older technology: telegraph. More precisely it is the power unit for an Army field telegraph. I'd guess that it has been re-purposed over the years into a 'worm shocker' or some other non-military purposed given the type of leads and clips on it.
http://www.worthpoint.com/worthopedia/antique-army-bell-hand-crank-telegraph-power-unit
Bravo.  Nicely done!  And quick too!  Thanks.
Re: Bravo.  Nicely done!  And quick too!  Thanks.
John McGaw
I should add that my 'naming the name' was based entirely upon that one search result. If the author was wrong then clearly I am wrong. It was amazing that the identical item showed up though. The field telephones that I've seen were single piece units and ran from a battery and had a crank to generate the ring voltage but I guess that your unit might have been part of a telephone rig with an external ring magneto rather than part of a telegraph setup. More research might turn something else up.
Not a field phone
Alan in Little Washington (NC)
It contains a magneto like the plunger type detonator and old fixed and field phones (growlers), in fact the manufacturer also built phone magnetos. But, because there are only two connections (none for a handset), a leather handle, and clip leads, I think it is more likely a mine explosives detonator. It looks similar to this Holtzer Cabot Magneto crank-style mine detonator:
The most common detonators were the push down type used in Western movies and cartoons (Willey Coyote), but they also made pull up and crank styles.
Interesting Google:Image results *LINK*
Tom Dunlap
I did a Google search for "GB 90530" and then went to Images. The results are interesting in a historical lineage sorta way...considering what the unit is and what turns up in the Google search.
Take a look! ;)
Tom
Images for GB 90530
Bravo II
Gary Smyth
Who knew. Two possibilities. I checked out the brand name and saw several other similar boxes. Mine has no name on the exterior. This week the cover come off. I will continue to look. I'm not sure how it works. Do you have to continually crank? Does it store energy? If a detonator, do you crank until something goes boom? I checked and the one I have, the plate says 10000, not 100000 as mentioned in other examples. Thanks to all. By the way, it's not nearly as old as I thought. It was grimey, I oiled the box with a fine light oil and with the grime emerged a scratched date "New - Oct - 1968".
PICs
Here is another Holzer-Cabot detonator. It doesn't have the leather strap but you can see the stud where it attaches. All photos of H-C detonators I found have only a single hole with what looks like a solid slide-away cover, but I believe to ensure the bells could be heard, your model had two holes, one for each bell, with screen covers. There is something just visible in the back which might be the clip leads wound around posts:
Holzer-Cabot had a number of inventions including magneto clocks, fire alarms, telephone/telegraph equipment, and according to Wikipedia in 1891 invented the first successful electric car!
