New to Spraying
New to Spraying
Bart Goldberg
New to Spraying
Bart Goldberg
I had finally broken out the brand new spray equipment that I purchased in good faith several years ago. As is often the case, I buy tools with the best of intentions, but don't always get around to using them for a lot longer time that I anticipated.
Anyway, I finally went through the tutorial DVD from Jeff Jewitt on how to spray and began practicing outside using just water. I got the hang of it and am now working on converting my son's old play house into a spray booth.
A couple of questions:
1) Do you have to use an explosion proof fan to spray solvent based finishes?
2) What is your favorite finish to spray and why?
Thanks Much
Bart
Re: New to Spraying
Re: New to Spraying
Dick Coers
Getting a vapor concentration that will explode is not an easy task. A running fan should never spark. A switch is another story. You would be better served to locate the switch outside the building. You may consider a belt driven fan that does not have the motor in the airstream, and located outside the building. An explosion proof electrical system is just not a fan, but enclosed wiring in explosion proof boxes. True explosion proof is strong enough to contain an explosion inside the electrical system without igniting the vapor in the structure. I designed wiring systems for natural gas compressors early in my career.
What I spray is based on the piece of furniture. Acrylic lacquer is my old standby, but not on a table.
Re: New to Spraying
Morning Bart,
You can go out an spend $500+ for an explosion-proof fan with the CFM your booth needs;
or
You can go down the street to Walmart and spend $14.95 on a 20" box fan.
Why?
The real deal is made from bronze and other non-ferric (non-sparking) materials, right down to the bearings, at close tolerances and has special motor(s) etc.
The Walmart special, however, is mostly non-sparking plastic, and uses a brushless induction motor so there is no sparking in the motor. The only spark source is the 3-speed switch, so you can avoid a problem by not switching on-off etc. while vapors are present. You can also rewire it to move the switch outside of the box and thus out of the air/vapor stream if you're so inclined. I've used just sucha fax in my take-down spray booth for years while spraying shellac, NC solvent lacquer, and reactive oil finishes, not to mention waterbornes. You'll need a couple of cheap furnace filters in front of the fan to catch finish and keep the fan clean. Start the fan before you start spraying and let it run for 10-15 minutes after you're done.
You'll reduce (eliminate) dust nubbies in your finish film if you slap a good furnace filter on the opposite side of your booth to filter the incoming air.
You don't mention it, but you're going to need lots of light inside your booth. Lights inside are, however, a NO-NO, whether due to sparks in the lamp sockets or finish build up on hot bulbs. Thus you'll need to cut holes in walls etc. fit them with some plexi or glass, and then mount spot lights to shine through from the outside. I solved this issue easily as my k-d booth was made of 7mil Visqueen tacked over a 1x2 frame, so I simply position a few big work lights outside.
Does all this comport with fire codes and OSHA? Not a chance. But for a weekend warrior, it'll do just fine.
Re: New to Spraying
Re: New to Spraying
Howard Acheson
Whatever fan you end up using, be sure it does not move the air too fast. Any of the 20" box fans tend to move the air so fast that it can effect the spray and the evaporation of the finish thinners.
You can easily and successfully spray any fast drying evaporative finish. This would include waterborne finishes, lacquer or shellac. Each has their own characteristics and require different set up and adjustment of your gun and compressor. What works for one, will probably not work for the others. Instruction (reading a book) and practice before attempting a real project is the only way to end up with a nice job. Work your way through Jewitt's book and you will learn a lot.
Avoid oil based finishes. They dry so slowly that the overspray is in the form of liquid droplets. These droplets will get all over anything in the shop or room leaving a nasty crust. Unless you have a self contains spray booth or room stick with the evaporative finishes.
Re: New to Spraying
Bart Goldberg
Re: New to Spraying
Bart Goldberg
Ive heard that that pre-cat laquers are really nice. Anyone have experience with these new water borne finishes? Any recommendations?
Thanks
Bart
Re: New to Spraying
Re: New to Spraying
mdclor
Bart,
I have used Target Coatings products exclusively, so I can't postulate on the relative merits of the various finishes. However, I am extremely happy with the results I get with their EM6000. They are easy to spray, give a nice finish and require very little, if any, scuff sanding between coats.
Here are a few things I have done with the EM6000.
I apologize that the finish doesn't show up better. The wood is QSWO in all three pix.
HTH,
Merle
Re: New to Spraying
Re: New to Spraying
David C. Lykins
Target Coatings makes some of the BEST water based finishes out there. I've used the older version of their "Premium Spray Lacquer" (PSL) and it worked quite well for a novice like me. My main issue was that my spray booth was in the basement and therefore was "too cool" temperature wise and I was getting poor results. So before I went in to spray I heated the booth with a little cube heater. I could have left the heater in the booth as there is no need to worry about spark or explosion since I was using water based lacquer. After that I got much better results.
Also, I didn't see anyone mention this, but at the suggestion of a spray guy at an autobody shop I had gone to, make sure your air intake is at THE TOP of your spray booth and of course FILTERED. And make sure your EXITING AIR is at THE BOTTOM of your spray boot as this will pull any overspray DOWN to the floor and not back onto the piece you're spraying.
Good luck, and check out "Target Coatings". "http://www.targetcoatings.com/"
Re: New to Spraying
Re: New to Spraying
Dick Coers
If you are talking about solvent based pre-cat, don't believe all the hype from the suppliers. I used it on my kitchen cabinets, and it is breaking down around the dish washer and stove hood. It's 20 years old now, but it didn't look too good in those areas after 10 years. It doesn't like moisture as much as Sherwin-Williams said it did. Also follow manufacturers film thickness recommendations. It will craze if applied too thickly.
Re: New to Spraying
Bart Goldberg
Re: New to Spraying
Bart Goldberg
I noticed that HomeStead Finishing has stopped selling the Target coating line, in favor of the General Finishes product line instead.
Bart
