The Trouble with Trunions....
Ed in NY
For 12 years my PM66's trunions have been operating smoothly, one hand needed to crank it up or down or tilt it to the left. Just recently the up down has gotten so stiff it's almost like the lock is on. My Powermatic manual suggests it's caked up pitch on the gear and teeth. So I've removed the table top and I'm about to clean it. The manual suggests oven cleaner followed by a non-hardening grease. I just want to get an idea of what others might do in this situation. The oven cleaner sounds like a good idea but I'd rather stay away from grease as it attacts more dust. I was thnking of using dry teflon lube. Anyone have any guidance for me???
Re: The Trouble with Trunions....
Jesper, Denmark
Jesper, Denmark
The oven cleaner is a bit corrosive, so my preference would be WD 40 or mineral spirits.
Dry PTFE lub sounds OK. I use Butcher's wax.
Ed in NY
I agree, the oven cleaner would destroy the paint. I like the idea of butcher's wax too.
Carol
One is a cleaner, the other a lube.
Nix the oven cleaner. Corrosive and toxic. You would need rubber gloves and a respirator. Use Simple Green or another such cleaner.
Any dry lube will work. Lots of them out there with the advent of CNC's. Your choice is fine.
Keith Newton
Did you try spraying the worm and gear from underneath first before removing the top?
Also loosen the hand wheels a ways and try to spray into the bushings where the shafts pass through the base housing.
Removing the top seems like a pretty drastic measure to me. LPS Magnum is the best lube that I keep in my shop. I used on the two screws of some of my hand-screw clamps, then had to use a solvent to take it off, because it was too slick. When I would tighten one handle, the other would loosen.
Delta recommendation, Oven cleaner BAD
Bill Tindall
I took a maintenance class from Delta many years ago and the instructor lubed the slidy parts and gears with Johnsons paste wax. I pack it in the gears and smear it on slidy parts now and then for 30+ years and I have never had to clean anything.
I don't know why there would be pitch on the gears and slidy parts. Pitch is acidic and anything basic will dissolve it. Oven cleaner is basic, so is ammonia, and window cleaner and simple green.
I would more suspect that old grease and worn metal debris is the problem. Hence, I would start with a stiff brush and kerosene and see if that removed the offending material. If indeed the problem is pitch and the solvent didn't remove it then I would proceed to simple green or window cleaner with ammonia. These products are completely volatile and nothing harmful will remain after cleaning.
Oven cleaner will remove pitch, and promptly. It will also render you blind if it gets splashed in your eyes while brushing it on gears and such. The problem is how to be rid of the caustic residue which will attack metals over time?
Phil
I recently cleaned my UNISAW for the first time in about a dozen years: a vacuum and some of this did the trick (I had no pitch, just lots of saw dust everywhere):
Re: The Trouble with Trunions....Phil???
Tom Dunlap
I had a bottle of that stuff in liquid, not spray. I lost it and can't find it anymore.
Where did you find it? Can you find a product number on the can?
Thanks!
Tom
Phil
I want to say Lowes: our Lowes has a display of lubricants in the general proximity of the power tool coral. I also have the non-aerosol version and found that it was more difficult to get the stuff into the nooks and crannies: the aerosol, with the red straw (that you notice is not taped to the side of the can, when you get home) allows you to get everywhere that counts.
Tom Dunlap
I'm an arborist so the liquid is nice to drizzle into carabiners and mechanisms. I'm heading to Lowes this morning!
Tom
Kneale Brownson
Re: Delta recommendation, Oven cleaner BAD
Kneale Brownson
I spray all the moving parts of my saws with TopCote
Ed in NY
Thanks for all the replies. Yes, I did try to clean the gears from below about a week ago by trying to chip out the pitch with an awl and screwdriver. It's in a really bad sopt and I couldn't get to everything. I sprayed a little rubbing alchohol on it and moved the gears and it worked perfectly.. I came back about 2 hours laters and it was just as bad if not worse. I decided to follow Powermatic's directions and remove the top. I had to realign the saw and level the tables with each other anyway so the table needed to be loosened. I like the idea of simple green and I'm going to go with that first and use oven cleaner as a last resort (using goggles) and, after I get it done spray it with some Teflon dry spray lubricant. I might have to disassemble the whole mechanism and lube the shaft that goes through the trunion too. I'm thinking it was caused by this one particular wood I was using recently. I forgot the name of the wood but I found some pieces in the parking lot of a Home Depot about 10 years ago...looks like mahogany or padouk, very dark brown and VERY dense. Almost feels like engineered wood.
Carol
Ed, please re-consider the oven cleaner. It is really toxic stuff, way beyond goggles and rubber gloves. Respiratory protection is mandatory. EMT's have been called when the fumes of the stuff overcame the person cleaning the oven. If you have other respiratory issues, using this stuff could result in a traumatic situation.
There are a number of pitch removers on the market. CMT makes one I use. It is very effective and very safe. A pint bottle at $15 may seem expensive, but is it a whole lot less expensive than a trip to the ER. And it is useful for cleaning your saw blades and router bits as well. That bottle will last a lifetime, at least at the rate I use it, and I use it generously when I do.
Please be careful.
Hal
I use wax, the same as I use for my saw, jointer, etc. table tops. Don't remove the table - rea PITA. Just remove the blade insert and reach down in with the blade removed. AND THE SAW UNPLUGGED!!! Keeps dust out of the works. An application lasts for quite awhile.
Rockler Blade Cleaner
Robby Wright in San Marcos, CA
Carol's on to something. I'll bet the stuff that Rockler sells as blade cleaner would work like a charm. It cleans a blade very quickly and is kind of like a soap that rinses off with water very easily. I bought one of their blade cleaning kits and it works like a charm, even on heavily pitch coated blades.
Almost any spray dry lube or wax that doesn't contain silicone would work fine for lubing.
Ed in NY
Thanks for the concern Carol...I actually sprayed Simple Green all over everything I could get it onto and woudn't you know it...Holy Cow!!! The thing turns with a pinky! Now this is the PM66 with the 5HP motor on it, it actually works smoother now than it did when it was new. I wiped off as much of the Simple Green as I could and ran ther trunion up and downa few dozen times to work it in. I'm going to let it dry for a day or two and then hit it with the teflon spray. Since I already took the top off, it's now time to realign everything.
Ed in NY
Thanks for the advice Hal. I tried fixing this form the bottom but had no luck and have already removed the top. It's actually not as bad as you think, I'm an old hand at it. I had to completely disassemble this saw (with a 5HP otor and the router extension table on the side) to get it into my basement. So I had the motor off, the trunion off and the table off. Reassembled everythng and it's worked well for 12 years!
Why I don't like the sprays
Bill Tindall
I have not found them to last very long. Johnsons paste wax packed into the gears and slidy parts lasts for months. Since this is an unpleasant job, I like to extend the time that it is necessary to repeat it.
2nd the use of CMT Bit/Blade Cleaner:Good Product
Frank Orfanello
Tom,
I'm sorry I am so late answering this too, but I got this spray at Lowes as well. This stuff is great.
Good Luck
