IPE deck sealer.
IPE deck sealer.
IPE deck sealer.
John Veerkamp
What is a good sealer for IPE or Goncalo Alves outdoor decks. The exposure is afternoon sun. This a small entry deck that is 4' X 6' with three steps up to it.
Thanks,
John
Re: IPE deck sealer.
Bill Tindall
I don't think Ipe needs a sealer. The wood is essentially impermeable to water which is why it lasts forever. The bridges on our rails to trails route were decked with IPE and nothing was done to seal. The wood weathered a sun bleached color.
Howard Norman
I have a covered 10x30' IPE deck that has been in six years without a drop of sealer ever being applied. Looks fine.
John in NM
With direct sun exposure, it will weather to a grey color, out here it goes quick, maybe a year or so (7000' elevation, lots of UV).
For finishes, I like both Penofin and Sikkens SRD. Both are thin and do not form a film, so you can recoat easily as needed. The frequency of re-coat will depend on the amount and intensity of sunlight, I get about 9-12 months, at lower elevations you will likely get 2 years or more.
I've also tried film finishes, they last about as long but are much harder to re-coat.
Alan in Little Washington (NC)
Like Bill and Howard, I never sealed my Ipe porch deck. It has grayed out. The only reason to seal it is to "attempt" to retain the reddish color. I figured once I sealed it I would need to seal it every year or so. It is a retirement house- so I didn't seal it.
Good question, John. I tried a couple different linseed-oil-based finishes and found that they don't dry on ipe, at least not within a reasonable time. I'm pretty sure that ipe has something in it (like rosewood does) that inhibits the drying or polymerization of oil-based top coats. I've heard that Penofin works, but I have not tried it. My porch is now aging gracefully without any finish at all.
In my area [New Jersey] most people I know let Ipe go to a "natural" gray as the result is about as close as you can get to a no-maintenance deck. Once you start putting a sealer on it, you've bought yourself a yearly chore for renewal, i.e. bleaching/stripping, power washing, reapplying sealers that change their formulations every couple of years to comply with regs.
None will penetrate
Lee Schierer McKean, PA
Where I used to work we tried to make a wood preservative and one of the woods we tested was IPE. What we found is that none would penetrate the wood surface. We coated woods with various materials and then did a cross cut to see how deep the material had penetrated. Basically none penetrated even 1/64 of an inch into the material. Our weather exposure tests showed virtually no difference between treated and untreated wood in terms of greying.
Lee
