Hide glue shelf life and stability
Bill Tindall
A statement was made in a recent class I took claiming that bonds made with liquid hide glue were inherently unstable due to additives in its formulation. I suspected this statement could be false so I consulted the chief chemist at Franklin glue company, Dale Zimmerman. In addition to answering this question he provided a convenient test for determining whether liquid hide glue had exceeded its shelf life. His response,
"Hide glue, once liquified, is, indeed, prone to change, and the chief factors in that process are time and temperature. Hot hide glues are generally mixed daily, and the unused balance discarded because the temperatures used in dissolving and applying them are dangerously close to the temperatures that cause them to rapidly degrade. A product such as Titebond Liquid Hide Glue is produced with controls to limit the exposure of the glue to heat in production, then stabilized to minimize the rate of change of the glue as it ages. Nonetheless, we recognize that that product will eventually change, and diminish in quality. While time is a factor, the rate of change is somewhat unpredictable and checking the physical properties of the glue before use is, perhaps, the best way to be sure it is still good. To check the glue, merely applied a thin layer of glue to a piece of paper or wood and allow it to dry. If that layer of dried glue is hard and
sounds almost like a countertop when tapped with a fingernail, the glue is still good. If the glue has appreciably changed, it will no longer dry hard.
One other factor, however, needs to be kept in mind. Hide glues are inherently sensitive to moisture. In fact, hide glue is hygroscopic, which means it is prone to draw in moisture whenever excess moisture is present. With that in mind, even good hide glue will fail to dry hard in highly humid conditions, so it important to avoid such conditions when testing, and using, hide glue. Ideally, hide glue is best suited to environments where humidity is modest and high humidity only exists during short stretches of rainy weather. Given such conditions, neither bonds made with hot hide glue nor liquid hide glue are prone to change over time. Bonds made with all hide glues are, however, prone to temporarily weaken during exposure to prolonged or excessive humidity, and stresses present during such conditions can allow bond degradation to occur."
