A55 Smoothing Plane
computer question
computer question
computer question
Bill Tindall
I access the internet through a Verizon modem that is plugged into the USB port of my desk top computer. It links me to a nearby Verizon cell tower. Since Verizon switched our area from 3G to 4G I occasionally get the message captured in the photo below. This message used to come up rarely and now it comes up every 3-4th time I log onto the Verizon cell tower. I only have one computer in the house and no neighbors for 1/2 mile so this message is bewildering. Any idea what it really means and how to stop it?
Re: computer question
John McGaw
Probably the best thing to do is to call Verizon and complain about the poor service. Yeah, I know that it means wasting time talking to a script-reading 'support' person but if the problem isn't on your end, and without a network it seems unlikely that it could be, then it is by default their glitch.
Kneale Brownson
Kneale Brownson
We had that occur the first year we used a Verizon aircard like that. Actually, it was an Altell usb aircard. What happened was we ended up not being able to log on at all because of this doubled ID, which turned out to be some software problem that occurred when Verizon took over Altell. You should contact Verizon and get it cleared up before you cannot log on at all.
del schisler
if you are using a aircard to log on maybe some one has got your log on info and log's onto your internet free ? and maybe at the same time and the comp. thinks you have a couple comp. ?? If you dont have a pass word pertect on your internet ? Just a thought
A different "take" than the others.
You probably have your computer set to "automatically" get it's IP address - rather than programming in a particular IP address.
Thus, there is a chance that your computer is choosing an IP address that someone's computer has already picked or possibly was purposefully assigned.
I would try and find a different IP address - possibly a unique one.
John McGaw
If that is the problem then things are even worse than they appear. Setting a computer to obtain a IP address automatically means that it is to query the DHCP server, in this case Verizon's system. And the one thing that a DHCP server may never do is to give two devices the same address. If anything the problem could be just the opposite of what you propose -- it has been given a fixed IP address which sometimes conflicts with what the DHCP server is trying to do. I would make sure that the computer is configured to always obtain its IP address (and possibly DNS addresses also) from the server.
Re: how do I do that?
Joseph Mulherin
Bill, I am in the same quandry as you...in that I do not know how to obtain these things to make my computer operate as others do. Like...Emails: POP3; and IP adress???? . WHY is it always something like a trade secret or security we run up against????? If they want us as customers then the knowledge should be readily available without jumping thru the hoops. I recently bought a "tablet" to use when I go out of the house, and it too needs to know these things before I can use it.
Try resetting the IP address *LINK*
Dave Paine
Bill,
Lot's of variables. I have hard wired connection, so very different than your wireless card. Google link has many hits for how to reset the IP address.
As stated in other replies, most people have a dynamically assigned IP address. This is done by the DHCP service in Windows (Dynamic Host Configuration Protocol). Which essentially says "Give me an IP address".
You do not state if you are shutting down the computer in between connecting to the Internet. It is possible that if the computer is not shut down, it may still have the IP address of the last session, and when you now want to re-connect it may go out to get another IP address - but for the same service. This could cause the error message.
Since I have a hard wired cable modem, I have a fixed IP address to the cable modem, and this I have a router to share the connection within the house.
My router then assigns "internal" IP address's in the range 192.168.x.x. These are dynamically assigned by my router, or in some cases, I have configured then to be fixed, e.g., for my Skype phone, so that I can then configure it's IP address to be what is called "Outside the firewall" which improves communication for the Skype service.
Good luck resolving this, especially if you have to contact Verizon.
http://www.google.com/#hl=en&safe=active&sclient=psy-ab&q=how+to+reset+ip+address+xp&oq=How+clear+IP+address+XP&aq=0q&aqi=g-q1&aql=&gs_l=hp.1.0.0i22.963l11140l0l14961l29l24l0l0l0l1l1673l14318l0j2j2j2j1j1j6j3j2l19l0.frgbld.&pbx=1&bav=on.2,or.r_gc.r_pw
Re: Try resetting the IP address
Joseph Mulherin
I typed in POP3-server and SMTP-server on my computer search headline and up came my individual server addresses. Now I can send and receive messages and pictures.
you may be on to the cause
Bill Tindall
The modem times out if there is no activity for a while and I have to reconnect to Verizon, but the computer stays on.
Re: you may be on to the cause
Joseph Mulherin
I sent several pictures to Ellis who said he would "upload" for me and post.
This "upload" is mystifying to me....you people use language and terms I
do not understand in this regard.
The FAQs says to push the "blue button" and upload....I do not have a blue button on my computer picture programs
John McGaw
The 'blue button' has nothing to do with your picture program(s) -- it is part of the WoodCentral forum software. You should see it when you are composing a message and wish to embed a picture. For example, as I type this, immediately above the text entry box is the entry area for uploading files:
And if I did it right there should be an image showing that feature. BTW, whether or not the button is blue will depend on your computer's operating system. The Browse button is blue on my computer when the mouse is hovering over it.
Joseph Mulherin
Sorry, John, I do not have it shown as you stated.... no blue button seen, no lettering at all, and "upload".
Guess I need to install a new Wood Central website program.....?
Joseph Mulherin
That has to be the correct reason I have been griping about since I started those chairs. Must have the WRONG forum software on my computer for WC. Need to have the correct address so I can download and install the proper one.;
You must register
Joe, I can tell by seeing that your name is in black instead of blue that you are not a registered forum member. Unless you register, you will not have the option of uploading images directly from your computer. Please click on My Profile and register yourself.
Thanks,
Aha! moment...
Joe, you're registered under the name "Joseph Mulherin, Sr." You need to reset your preferences to this username, then you'll have all the privileges of membership. Every letter and comma and period is part of your profile, so anything else will generate an error message. Sorry for your troubles, but this is a system that keeps spammers out of our messageboards.
Our system relies on "cookies," small files that contain your member info and other forum settings, to recognize you when you sign in here. Registering a profile affords you lots of perks, including the ability to upload photos directly from your computer into your forum posts. All of this is explained in our FAQs file, linked from the gray navigation bar above.
Once you register, you must use that username every time you post, or else our system will send you error messages saying that someone else owns that e-mail address.
If any of you have ANY trouble at all with the registration process, please let me know.
Ellis Walentine, Host
