Have a question? Ask Woody!
staining and finishing
Joseph Mulherin
Applied some dark walnut/poly to the first chair. It still shows the grains in the wood. will wait until it totally drys and then if it does not meet my standards for looks after applying second coat then I shall just end up painting it.
The chair does sit and rocks well. Second chair is of the same design and I shall see how it too stains before painting both if needed.
Re: staining and finishing
Joseph Mulherin
Second coat on first chair darken it up a bunch. Second chair has just had its first coating and it looks a lot better than the first. Additional coat tomorrow will tell if they get painted or not.
Am thinking they will go to granddaughter's house for patio rockers.
Joe, one way to color the grain uniformly is with dye stain prior to topcoating. I'm not a fan of colored varnishes, as it is too difficult to control the buildup of color, and subsequent coats can leave the wood darker than you might want.
Joseph Mulherin
Ellis, I coated the entire surface of both chairs with 2 coats each of Varathane Dark Walnut w/ polyurethane. Wiped them down with a green pad and waxed the seats, arms, and headboards w/ beeswax.
Wiped them down again and polished, then loaded them up in my
Van and took them to my granddaughter's house to be used on their patio. We live here in the Palm Springs area(Indio) and do not get maybe 3.5" of rain all yr. But the poly should keep any moisture from ruining the wood.
The whole idea of me doing these chairs was to give me somethning to do in my retirement yrs and to make something for the relatives to have I had made after I am gone from this miserable world
I have 3-5 more chairs to do the rest of the yr.... different designs and the last one will be the desk chair like the say Thomas Jefferson worked at.
new chairs
Joseph Mulherin
The next two chairs will be the Sam Maloof inspired rocking chair. I have several pictures and measurements and can see they are mostly hand made using mostly sanders for details.
Basic chair is 46"high, 26" wide, and 48" on rockers length. Walnut is not readily available around here for me, have to travel about 86 miles to Ontario, CA. Will probably make mine using oak.
Re: new chairs
Joseph Mulherin
Bought some more spruce and am making the Maloof chair copy with that to work out some details on construction techniques. Laid out and bandsawed most parts, sanded with
ROS to rid parts of bandsaw marks. Seat will be sculpted on Shopsmith using Charles Neil's daddo blade layout like I did on the other chair(which turned out marvelous). Am departing a little from Maloof's design in that I am placing some curved blocks glued to the joints fore and aft of the legs on rockers, and arms to back stantions. These will be smoothed out evenly to join in smartly to main joints....and they are for greater strength. Back design and headboard to be determined later.
If chair works out as expected I shall purchase some walnut or mahogany to make the others.
Granddaughter's chairs
mdclor
Joseph,
You didn't tell us how much she loved the chairs or you for making them for her. C'mon, brag a little.
Merle
Re: new chairs
Bruce, a MN Galoot
This is going to go a lot better if you take some pics along the way. :D
Re: new chairs
Joseph Mulherin
Bruce, I have said this before....I do not understand how to post pictures I have taken of my work... and the instructions listed on the FAQs does not register with me. Have asked several people to help me on this but no help anywhere.
Re: Granddaughter's chairs
Joseph Mulherin
No, Merle, she has not made any comments on them...only been three days since I took them over.
I have [ictures of them but still do not understand how to post them to WC.
Posting photos
Send me the pictures, Joe, and I'll upload them for you.
Joseph Mulherin
Ellis, I would send the pictures directly to you, BUT, the email wants to knw the POP3 and the IP address I am at....don't know them and do not know how to get them..... Call the Verizon???
Joseph Mulherin
Found out the addresses I needed to send and receive messages and pictures by typing in POP3-server and SMTP-server on my computer search headline and up came the addresses I needed to email them.
Re: Posting photos
Joseph Mulherin
OK, Ellis, I have sent several emails with pictures...on Sunday morning. Hope these show you guys what I have been doing. The chairs do sit and rock well. For the next chair....a Maloof copy... I have decided to not use Tightbond glue...rather decided to try using "liquid nails", and so far it has turned out very good...squeezeout has been minimal and is swiped off with a spatula. The boards seem to be held better and setup quicker.
Am bandsawing the new chair seat to shape, will scope out the interior contours with my sanders.
Then cut in the openings for the front and rear legs; bolt them to the seat and drill dowel holes in the bottom of them for mounting on the rockers; Then there will be a whole lot of disc sanding to finalize the chairs contours. Seat back and upper headboard have not been touched as yet.
More later....Joe Mulherin
joeirish
Finished up on first two chairs and took them over to granddaughter's house for their use on their patio.
Started on third chair....a copy of Maloof rocker; cut rocke3rs, arms, back braces, legs on bandsaw the other day; Installed them today to seat, and made my back design oSat in seat and it does sit welln posterboard for when I do them.
Am going to do the designs with 1/8" laminates for curvatures after I make the form from MDF.
third chair
joeirish
Tried sitting in the chaiir and the seat cracked in two.....so have to remake
Here are your photos, Joe.
I know you're still working on posting photos, but in the meantime, I'll post the ones you've sent me so people can see what you've been doing. Here goes...
Re: Here are your photos, Joe.
joeirish
Thank you, Ellis, call me on Monday and we can get the proper setup on WC for me to take and send more photos along with some comments.
The third chair seat cracked and I salvaged the inner portion, but the pouter edges I am going to have to remake and sand the curvatures...rest of chair held together good. This is only a practice chair so I can get the techniques I want to use down correctly before I go and buy some more expensive wood to make the planned 4 chairs of this style I want to make. Final chair...along towards Thanksgiging will be the desk chair
Re: third chair
joeirish
Learned a lesson.....liquid nails should never be used except on flooring and roofing
Titebond 2 from now on only. Saved the inner portion of the seat, just have to remake the outer edges and sand the curvatures....then reassemble the legs and arms to the seat.
Nice work Joe!
Don Orr
Thanks for letting us have a look at what you have been working on. And thanks Ellis for helping.
Re: Nice work Joe!
joeirish
Thanks, Don, the credenzas and desk were made in 1978 when I purchased my Shopsmith.
Bruce, a MN Galoot
So, THIS is what all the fuss is about! Nice job, Joe. It's good to put pics with words. I'll be looking forward to the finished product. Any idea why the seat split?
joeirish
Hi, Bruce, yes those chairs were the premise of the ongoing ranting I did about posting pics to here on WC. It seems I do not have the proper setup with the "buttons" needed tpo upload, etc, or the proper WC firum setup. Ellis is going to be calling me on Monday morning and he is going to instruct me on just what we need to do to setup mu computer so I can take and send pics with comments as I work on other projects.
Now as to the third chair seat splitting...I did not use a cross laid boards glued to the upper seat boards.
Went thru the scooping out using my daddo blade and then sanding the curvatures with my anfle grinder sanding disc. Sat in, or at least tried to sit in the chair the other night and of course it split into sevelal pieces. I did not use glue on the joints either...tried using liquid nails....do NOT ever use that stuff for furniture....ever!!! Saved the inner sculpted boards, shall glue them up with Titebond 2 glue, make another boards setup and glue it underneath at 90 degs ; the sand the edges to finalize the seat edges again. Am going to remake the legs using 1 1/2" spruce and cut them into the seat and bolt them.
Also rockers are going to upsized to 1 1/2" wood. Final sculpting will be done using my sanders to try to achieve the tender look of Maloof's chairs. This chair is my third and is a practice chair to get the proper construction techniques in mind before purchasing some more expensive wood for the 3-6 more chairs
I intend to make this year. Final chair will be the desk table chair....probably arounf Thanksgiving.
I have decided to make these chairs for family members....and to give me something to do to occupy my retirement years. Have made 6 poker tables; 19 mantle chime clocks, four rocking baby cradles;
2 matching credenzas and the double-roll desk. Also made two matching chairs to the sofa my younger son made yrs ago. Made a rolling cabinet for our larger TV with drawers underneath and VCR and players above.
joeirish
After I make the outer edges pf the seat, to strengthen the underside of the seat I am thinking I will use some 1/2" plywood glued and pin-nailed(1" pin nails) at an angle to the seat underside. Then reinstall the legs and rockiers and make the seat back braces with 1/8" laminates(5 per slat) ,
Have some medical peoblems which are going to hold me up for a couple weeks before I can concentrate on finishing the chair sanding for the Maloof contoures I like.
Experiment chair.... but will keep for myself. Other chairs (3-6) will be made from Mahogany or Oak.
mdclor
Joe, it is great to see the pix of your chairs. All this time, I thought you were just "funnin" us about the alleged chairs you had made. :D They look great and keep up the good work!
