Why?
Bill Tindall
To get a useful answer to your question it would be helpful to know why you want to build a scrub plane in the Krenov style plane form. For example, the answer could be you need a scrub plane and building one would be cheaper than buying one from Lee Nielsen. Or, it might be you just want to try you hand at building a plane. Or.....?
General thoughts. A cheap and effective route to a scrub plane is to buy a used, cheap Stanley #5 and grind the blade to a scrub plane configuration. This is the path I took and it works for my needs. Krenov style planes seem to me to be more suited for more precise planing. My favorite plane is a block plane made in the Krenov style. Choking the throat with shavings can be a problem with Krenov style planes, a problem made worse by using the plane to hog off lots of material. So making a Krenov scrub plane is a less obvious choice than other plane styles. But who knows, maybe by opening up the mouth it will work just fine.
