sharpening/grinding systems
Carol
I am thinking about an 8" slow speed grinder. I have a 1" belt sander that I use for turning tools. I have a 6" high speed grinder I used for hogging metal, like lawn mower blades and axes. I use the Wolverine with both as the situation dictates, but am getting better with free hand sharpening. I also have the WorkSharp 3000 which does a wonderful job on chisels and plan irons. I have 8" wheels. I did once buy an 8" slow speed grinder but took it back as the shaft was bent and there were no more in stock.
So the question is, what does the 8" slow speed get me that I don't already have. The reason I am asking is that I am designing a cabinet to store sharpening stuff and I need to know if I need to design in a space for this.
Re: sharpening/grinding systems
I have a two speed 8" grinder. I had a 6". I don't miss it.
I believe the geometry of an 8" grind is better than that of a 6".
Archie
In a world of multitudes of opinions....The bigger the wheel the better. For mass grinding, your 6" is more than adequate. For less hollow grinding on turning tools, the 8" or 10" is much better. However, I've got three grinders (ss 6"; ss 8" with 60/100 grit wheels; and a 10" Tormek) The Tormek is fantastic but slow!!!! The 8" has vibration issues but is fast--just not quite accurate enough. Between the two grinders, I like my 6" better--but, hey, it's a Baldor. The Tormek is quite worth the money for precision for sharpening bowl gouges but then a knife sharpening system (about $2k, which a friend has) is even better--and fastest of all.
Carol
The 6" high speed grinder is a 60 year old Craftsman with the world's most amazing bearings. Runs forever after the switch is turned off. Gonna keep it. It has the original grey very coarse wheels on it. It has a purpose for grinding, not for sharpening. IMHO.
Keith Newton
Carol, If you are not grinding so much that you are bogging down the motor, or having to worry about down time from having to change wheels too often, there probably won't be a lot of gain for you.
While the 8" slower speed, usually has a more powerful motor, the peripheral speed is about 2/3 of the 6". The volume of the wheel almost doubles, so the price will usually reflect that.
I usually find myself using a very light touch when grinding my blades, mainly to keep from drawing the temper, so the power issue doesn't have much relevance if you are like me.
However, sometimes when I'm making a tool, I may want to really grind hard and fast for that, I use a Koolmist system to keep the heat down. That little unit will turn any cheap grinder into a cool cutting unit for ~ $40.
What I do
Bill Tindall
The context here is sharpening not other grinder uses......
I use a 7" grinder for the reason that one can buy cheap surface grinding wheels in a multitude of compositions. There is no practical difference between a tool hollow ground with a 7 vs 8" wheel. The 7" wheel moves slower and maybe that is also an advantage.
I hollow grind the tool edge using a soft (H or I grade) crowned wheel, in the 60 to 100 grit range. I use free hand back and forth sweeping passes engaging the wheel just past the leading edge to minimize the risk of dubbing the leading edge. And a very light touch. The wheel composition is much more important than wheel speed.
Next I straighten the edge on a fine diamond plate, follow by honing on the stone of your choice(I use 1 micron diamond on cast iron).
