ATV Recommendation Requested
Yonak
I'm looking to get a vehicle to carry firewood out of the woods using a small trailer. The terrain isn't extremely rugged, but it is somewhat up and down, and I would be travelling over branches, some rocks, but not large rocks, small bushes, briars, etc. .. not through water, generally. The trailer capacity is, probably, 200~250 lbs.
I was thinking about a John Deere Gator, but my neighbor thinks I need something more like an ATV with knobby tires and higher clearance.
Of course, the exact vehicle will depend on what is available on Craig's List, or other source, but what I should be looking for ? I wonder if, like, a 450cc or 500cc 4X4 would do it ?
Is a winch necessary ? What is the purpose of the winch on ATVs, anyway .. are they job-specific, or are they mostly for pulling yourself out if stuck in the mud ?
If anyone has any advice on specific vehicles, general requirements or sources, I'd appreciate it.
Re: ATV Recommendation Requested
C. John Hebert
I have a Polaris 500 4x4 sportsman and you wouldn't believe the work it does. From plowing 2' snow storm up a 300' drive to hauling 12' x 18 hardwood logs out for sawing. I have a high clearance tandem trailer for hauling dirt etc and this thing is just as good as it was when I bought it. In winter, chains go on the back tires and it's unstoppable. I also have a cab in the winter to keep the snow off me
Service support
Tom Dunlap
If you're buying used the most important thing IMO is finding a nearby service/parts vendor. Sure...mailorder might be cheaper but when somethings broken time is the issue. Find a dealer that has a stock of parts on hand. If they have empty parts shelves then you're better off mailorder.
4x4 with 500cc is all that you'll need
When I ran my tree care company I had a 500cc that I built into a mini-skidder. It would haul 8" dia. trees/limbs whole with no limbing. I rarely ever used the winch. if you can find a closeout at Northern it might be worthwhile. Otherwise, be smart about where you drive. If you do need to get out it isn't expensive to have a cable come along and some strong rope.
A big issue is belt drive like Polaris or snowmobile or a geared tranny. If you're going to be hauling a lot of heavy loads up and down hills a geared tranny is better. You can put it into the proper gear and it won't creep or over drive like you might get with the belt drive system. For play and trail riding a belt system is OK...again..IMO and having worked ATVs hard.
At my last job we had JD Gators...Pfffft...don't waste your money if you want something to work. Especially off road. Gutless and expensive!!!
Tom
Jim Hager
I have recently picked up a JD Gator off of Craigslist and am thrilled with it. It is a 2004 with 115 hours on the engine, no paint worn off of the floorboards yet and has been garage stored it's whole life. I plan to use it on my place to haul firewood, pull a small utility trailer, hunt and do general yard pickup work. It's as high off the ground as my son's Honda Rubicon and is a 4 wheel drive to boot. Basically it's an older guys ATV plus the wife can ride with me more comfortably than on a 4 wheeler. My grandson thinks it's great and always wants a ride. I looked at several Gator, and other brands new and the price I gave was well less than half of new. I'd do it again in a second.
Re: Service support
C. John Hebert
I use a very short chain so the log is about 2' when strapped. It helps the log from digging in to much as a longer chain would. I sometimes use tongs to a trailer ball. Those work pretty decent also. If you want more info you can contact me at my email address cjohnhebert@rivah.net
