Cottonwood advice needed
Cecil Nickerson
I have access to some large Black Cottonwood logs which can be milled to my specs but I don't have any experience with this wood and wonder if it's usable at all. Perhaps in place of pine or spruce? Any and all ideas would be welcome 'cause I'm stumped (no pun intended).
Thanks, Cecil
Re: Cottonwood advice needed
Free wood is good wood
If you don't have to pay too much for it.
I like cottonwood. It is light, easy to machine and generally "non-toxic".
The drawbacks - it is FUZZY. It can sometimes be a PITA to sand. I guess it has shorter fibers than some of the others. It carves well. I find it similar to basswood in properties - but that could be just me.
I don't find it to be a "strong wood" - I think it doesn't have much structural strength unlike white oak, red oak or whatever. It is soft.
I've got a couple of planks of basswood and a couple of planks of cottonwood that I use pieces as needed.
YMMV of course.
Re: Free wood is good wood
Tom Dunlap
I had some c'wood milled into lumber and built two nice sheds out of the result. It went up green and dried afterwards. The planking ended up with gaps but tarpaper was a cheap water/windproof siding. Using c'wd allowed me to save my good wood...ash, oak, maple...that was milled for higher end uses. Shop shelving/storage comes to mind. I have no clue how it would work as 'fine woodworking' though.
Tom
Re: Cottonwood
It's a fav for horse stalls because they (horses) won't "crib" (chew) it. Reason being that it fixes a high amount of urea so they hate the taste. Got some wet and turned a few bowls. Wife wouldn't let me or it in the house. Clothes got shed in the garage and I got a cold hose shower before the doors got unlocked. Smell dissipates when fully dry.
Soft and fuzzy as mentioned; you'll be using sanding sealer to control grain tare-out. Look to dimension by drum sander rather than planer. Fast-growing so lots of summer grain. More than it's share of seasonal movement. Good for outdoor projects. Not worth it for interior use or furniture.
YMMV
Thanks gents, I'll let you know
Re: Thanks gents, I'll let you know
Jim Breeden
I use it for turning - so - I grab every piece I can find. The grain is fantastic, at least for what I use it for. 8)
Cottonwood is soft, weak and very fuzzy, but it can be beautiful, too. I have some outrageously curly cottonwood that I've been saving for something special. You might be lucky and have some really curly stuff in your log. Wharton Esherick carved several of his monumental sculptures out of cottonwood, presumably because it is so soft and carves easily.
Thanks again everyone!!
