Cradle
Cradle
Cradle
Paul Woolson
Hi all,
I've been working on this cradle for several months now. I'm a guitar maker by profession so I had to fit it in between "real" wood projects. I'd love to hear any thoughts/criticism to better myself on future projects like this. Thanks, Paul
Re: Cradle
Re: Cradle
Bill Tindall
Looks just fine to me. I like the lighter colored wood for this piece.
Re: Cradle
Questions
Gary Smyth
How is the "swing" mechanism designed" Is the pivot metal or wood? Is it permanently captured?
My picture has shadows. I take it the slats mortised in? Or, are the spaces between the slats below the mattress flush with the frame? My thought is with baby stuff accumulating in any "hollows" below the mattress if they are not flush.
I like the angled sections where the top of the slats meets the ends.
This appears to be cherry wood. It looks good now and should mellow out darker with exposure. Did you sign it?
Very nice. Someone and/or future someone's ought to be thrilled.
Re: Cradle
Re: Questions
paul woolson
Hi Gary,
The swing mechanism is a turned pin that looks like a "T" when you view it from the side. That slides into a keyway in the cradle so that it is effectively locked in. There is also a wedge glued into the keyway so that it wedges everything tight. The cradle just slides downward onto the pins and it all locks in place. Easy peasy!
The slats are placed into a mortise that runs the whole length of the rail. I made spacers that are the width and depth of the mortise and the length of the space between the slats. It made for pretty easy assembly.
So everything is flush, you are probably just seeing the edge of the mortise/spacer in the photo.
The angled moldings were sort of an afterthought. Something just didn't look right about the construction so I cut a piece and laid it on the joint. I really liked it so I did that for one whole edge and stuck it with double faced tape. Came back the next day with fresh eyes and really liked it so I continued with that design.
It might just be the bad iphone photo but it's all maple. With velvet oil for a finish. Kind of a honey color though it's supposed to be clear. Ironically, it matches their floors perfectly.
Yes, I signed it. My hope is that they loan it out to other parents and each one writes the baby's name and date on the bottom. That would be a wonderful sight after 50 years or so.
Re: Cradle
Re: Questions
Mark
I think it looks great.
However ...
Looks hard to tune but easy to play
Good for rock and roll, maybe some swing, definetely lullabies
And in the end ...it will be very special to someone....well done.
