OT Sheetrock
OT Sheetrock
OT Sheetrock
Alan
I'm finally remodeling my basement and have removed the paneling (circa 1977). It was partially glued to the underlying unfinished sheetrock. Most of the panels of sheetrock have some damage to the paper from the glue. Is it reparable or should all the sheet rock be replaced?
Thanks
Re: OT Sheetrock
Re: OT Sheetrock
Its a question of degree. Is the face paper completely gone exposing the "rock'? How large are the areas? Small areas can be patched fairly easily patched. OTOH it might be easier to laminate another layer over the existing stuff. Check around and you might be able to find some 1/4" rock.
Re: OT Sheetrock
Jason Roehl in Lafayette, IN
Quite repairable.
First step is to cut back any of the sheetrock facing paper that has lifted.
Next, sand the "defaced" areas with (preferably) an ROS and 80-120 grit paper to remove the largest bits of fuzzy paper.
Coat defaced areas with Zinsser's GARDZ.
Sand again when dry and recoat with the GARDZ.
Mud/sand.
Prime/paint.
Jason
Re: OT Sheetrock
Re: Quite repairable.
Alan
The damage is generally in vertical strips, almost the height of the wall and variable in width, up to ~4 inches. I'll give this a try, thanks.
Re: OT Sheetrock
Re: OT Sheetrock
steve mackay
Oh Brother I feel your pain ! I came "this close" to replaceing the sheetrock. This whole place either had paneling or MIRROR glued to the sheetrock ! Just scrap off as much of the adhesive as you can (level), skim it with joint compound (sandable), spot paint with KILZ then two coats of KILZ over all. I know it sounds pricey but when you're done its "like it never happened". Honest !
