2 x 4 length
Vicki Horseman
Im trying to build a wishing well that i found on a website and its missing a peice of specific information. A ring is made up of 14 2x4's cut on a 32' angle what I don't know is how long the peices need to be.
2 x 4 length
Vicki Horseman
Re: 2 x 4 length
Moses Yoder
If you know the diameter of the circle the length can be figured out. If not, then not.
Re: 2 x 4 length
Yonak
Vicki, decide on what outside diameter you want your wishing well to be and divide that dimension by 4.5 That will give you the length of each segment at it's long edge. Good luck with your project. It sounds like fun.
Re: 2 x 4 length
Yonak
After thinking about your question a bit, I may not understand it. For a ring made up of 14 segments, the angle of each segment should be cut at a little over 77°, not 32°, so I guess, without seeing your plans, I really can't answer your question adequately.
If you have the online site address post
Gary Smyth
it here for additional viewing. I'm confident someone will assist.
It is called a wishing well, because,,,,,,,
Keith Newton
You wish you had another plan where the math worked. You haven't given enough information for anyone to understand how this project should look. Or maybe I'm just too stupid to figure it out.
Re: 2 x 4 length *LINK*
John McGaw
Just a guess, but is this it?
Shop Shots
Re: 2 x 4 length
Yonak
I'd sure like to see that plan to see where the 32° comes in.
I can envision a scenario where something slightly greater than 32° could define an 11-sided figure, but, I'm just not gettin' it.
Re: 2 x 4 length
Keith Newton
Yep, 14x 32= 448º, and if that is the cut angle on each end of the 14 pieces, that comes to 896º.
If there are 14 sides, I get 18.85º for the cuts, if square reads 0º, like on the TS, or miter saw.
Re: 2 x 4 length
Calvin in Irmo, SC
Assume a 30" diameter circle, which equals 94.25" circumference, Divide by 14 segments which will give an approximate length of 6.75" per segment. Divide 360 degrees of the circle by 14 which equals 25.7 degrees total for each angle. Cut each end of each segement 12.85 degrees (i/2 of total angle).
Actually 15 pieces would be easier--approx. 6.25" per segment with 12 degree cut on each end.
Re: 2 x 4 length
Keith Newton
Calvin, I agree with this much of your post. "Assume a 30" diameter circle, which equals 94.25" circumference, Divide by 14 segments which will give an approximate length of 6.75" per segment. Divide 360 degrees of the circle by 14 which equals 25.7 degrees total for each angle." But beyond that, I would like to point out that the 25.7º angles are all the tips in the center.
Each of those angles is the apex of 14 isosceles triangles, like the middle of a pizza. All triangles have a sum of 180º. Subtract 25.7º equals 154.3º, divided by two, = 71.15º for the other two corners.
Since most saws read 0 when it actually cuts 90º, 18.85º is the reciprocal of the 71.15º. I could be wrong, but I'll bet you your favorite beverage I'm not.
And Vickie, I would like to remind you to use treated, or other rot resistant wood when you do this. It would be a shame to have it rotten or eaten by insects after a year.
Re: 2 x 4 length
Vicki Horseman
http://www.woodcentral.com/shots/shot149.shtml Yes this is what I would like to build. I tried the 32' angle and can get 6 peices to make a circle. It seems that the angle must be much lower. I did get a response that I'm going to try. If not I will keep tinkering until I like the result. Love a good challange and project. Thanks for the responses.
Angle!!
Vicki,
If you want 6 sides to your "rings", the miter cuts must be 30° not 32.
Other options: 12 sides - 15°, 10 sides - 18°, 8 sides - 22.5°
Wishing you well on your project!
Oops, my bad, I hate waking up to egg on face.
Keith Newton
MY math was wrong. The actual angle is 77, with reciprocal of 13.
Sorry Calvin, I may owe you a beer.
Re: 2 x 4 length
Carol
Consider this: Your shape is essential a circle. Divide your circle into the number of segments you want. Divide the number of desired segments into 360 degrees. Example, ten segments is 36 degrees. It doesn't matter how big the circle is, the angle will always be the same. The length of the segment you want is determined by the diameter you want.
I'd draw out the 2 lengths of the radius of the desired circle. You can do this on the computer, like with SketchUp. The angle between them is determined above. Measure the length of the segment between the two ends of the radi, and bob's your uncle.
Re: 2 x 4 length
Vicki Horseman
Wanted to thank everyone for their help. Turns out my original numbers were wrong. I was reading directions off of a link/pic on this site. What I discovered it if you cut 2 x 4's on an 18' angle ( someone mentioned this) at 11 1/8th you get a nice sized circle with a 36 inch diameter. Have to buy a few more 2 x 4's but it is a lesson I won't soon forget. Thanks again for the help.
Vicki
Re: 2 x 4 length
Yonak
Vicki, your plan should make a nice-sized wishing well. You may not need to buy as many 2X4s as you may have thought, as what you have in mind will make a 10-sided well, not 14. Have fun.
