Round Sanders?
Round Sanders?
Round Sanders?
Todd Kudirka
I'm looking to make some table top stands and want to make it to where I have places to set my salt and pepper shakers. I can't seem to locate and sanding device that will allow me to (counter sink) if you will, the wood about 1/4 inch or so in a clean, level way. I guess it needs to be about 3 inches in diameter.
I was think some type of drill press attachment???
Any suggestions?
Thanks.
Re: Round Sanders?
Re: Round Sanders?
Keith Newton
I would use a router with a template to guide the router, if it were me. You can use either a bearing over bit, or a guide bushing in the base.
a good 3" bit is pretty costly, plus they need a lot of power, which you DP may have, but they are more dangerous than most would expect. I have one friend, who lost a finger to one.
Re: Round Sanders?
Easy *LINK*
1. Using a fly-cutter [circle cutter], cut a hole the size you want in a block of MDF as a pattern/template.
2. Mount the template on your table top and use a guided router [see link] to cut your depressions.
Pattern Bit
Re: Round Sanders?
Re: Easy
I second this (or third or whatever).
I had to remove a lot of waste in a LOT of wood. I got the 1 1/8" pattern flush trim bit. Worked like a charm.
Re: Round Sanders?
Re: Round Sanders?
Yonak
I had a similar project a long time ago and it was easy enough to do in two pieces. I cut a ring the size of the lip, oversized on the outside, and sanded with a sanding drum on the inside. Then glued it, and tacked from the bottom, to a similarly oversized disk. When dry, I sanded the outside using a sanding jig on a disk sander.
Re: Round Sanders?
Re: Easy
Keith Newton
Mark, did you notice that they bit which you linked to, is shown a bearing on the bottom would be a better choice. And while that bit will work with a template, that long cutting length would need the template to be positioned high above the surface for that 1/4" depth. But that second one down might be a better choice here.
