Haze in finish revisited.
I got most of the haze out of the finish on the altar. I used a steam iron and a clean shop towel. Pressed it several times for a minute or so each time. It worked well for the flat portions. I got the vast majority of the haze out of the finish - there still is some residual "ghosting".
I succeeded somewhat on the flat portions of the trim work - i.e. the parts with a flat bevel. I didn't really succeed with the trim with a little bit of curve - this is also more damaged. I am going to try next week with acetone and possibly some lacquer thinner.
Re: Haze in finish revisited.
Bill Tindall
I don't remember this problem discussion but if the problem resulted from moisture and the material is lacquer then a strong solvent of higher boiling point than acetone will work best. "Retarder" which contains high boiling strong solvents will be ideal for the task.
Dale Lenz
Agree w/ Bill and will be easier.
Re: Agree w/ Bill and will be easier.
Ken Oakley-Sunny St. Cloud, FL
dry it with a hair dryer prior to spraying on finish.
