fret saw blade holder
McKay
What kind of blade does the knew concept have? Is it a typical scroll saw blade?
TIA
McKay
TIA
Blades for jeweler's sawframes *LINK*
David Barnett
It takes plain end (no pin) 5.125" jeweler's sawframe blades (it is primarily a jeweler's saw). For woodworking/dovetailing common sizes might be the 12.5 tpi skip-tooth from Olson or the 15 tpi skip-tooth from Lee Valley (which may also be from Olson for all I know).
Olson's are ubiquitous and acceptable for woodworking. Far better blades are available for sawing metals and other materials, jewelry fabrication and so on.
Knew Concepts makes a truly fine saw, although it's somewhat overkill for dovetailing, in my opinion. I'm only mentioning this because one can easily get by with a less expensive jeweler's sawframe or fret saw for woodworking.
Great for blanking tool steel for die forming, piercing, cutting shell, ivory, and so on. You won't be disappointed in its functionality or quality. Also order some McQueen's Mutton Tallow from Lee Valley. Mutton tallow is a terrific saw lubricant.
Olson skip-tooth blades
