knew concept fret saws
McKay
I have and love my stanley coping saw. However, the very narrow blades that I use to waste dovetails is no longer being made so I think that it is time to get the knew concept saw. Is there a link to purchase the saw through WC?
Thanks IA.
Re: knew concept fret saws
David Barnett
Lee Valley, a major WC sponsor... *LINK*
David Barnett
...carries a couple models, at least.
Knew Concepts saws
Re: Lee Valley, a major WC sponsor... *LINK*
Wow that's pretty cool but my Jewelers saws work awfully good at $12.95. I checked Riogrande and they have the new fret saw considerably cheaper than Lee Valley
http://www.riogrande.com/Product/Knew-Concepts-Jewelerrsquos-Hand-Saw-Frame-with-Cam-Lever-Tension-5/110147?pos=17
David Barnett
Not exactly, John. No 'Swivel Blade Clamps' *LINK*
David Barnett
You may not have noticed the difference.
The Rio Grande 5" saw lacks the blade swivel feature that's especially included by Knew Concepts for woodworking, which sells for $95 directly from Knew Concepts, which is what Lee Valley asks, as well. As the poster asked for a WC sponsor, I directed him to Lee Valley. Rio Grande doesn't carry either of these saws.
Knew Concepts make 5 different 5" saws. The 5" Woodworker Aluminum with Cam-lever & Swivel Blade Clamps has the plain (not red) handle, too.
You're right about not needing a Knew Concepts saw for DT's, of course, but if someone has the money and wants one, it's a damned nice saw. Not for me to judge.
I have a saw that, in my opinion, surpasses the Knew Concepts saw in features, rigidity, aesthetics and cost. The handle is articulated and canted to ergonomically disengage the wrist, allowing part or full hand pronation for endless sawing comfort and accuracy without strain of the common vertical inline handle. The handle is even adjustable for length and thickness and has tabs with promote the lightest grip. Problem is, you can't buy one of these. It's mine. I designed and made it for myself and I don't plan to produce them. I don't have a swiveling blade clamp nor do I need one, but I've also never used my saw for dovetailing.
Knew Concepts 5" Woodworking & Titanium Hand Saws
David Barnett
Another thought
David Barnett
You might search the archives for Derek Cohen's posts on his use of the Knew Concepts saw for dovetailing, or come over to WC Hand Tools messageboard and ask for his opinion on the saw and best blades for it.
Re: Not exactly, John. No 'Swivel Blade Clamps'
Your right David, didn't look close enough. I have an old coping saw I've used for many many years to cut all sorts of things from carving on the bottom of bowls to dovetails. Can't believe I'd need anything else except possible a deeper throat. I picked the one up I have now at the flea market many years ago and probably paid a buck or two for it.
David Barnett
Hard to tell the players without a scorecard *LINK*
David Barnett
Tools for Working Wood offers Olson saw frames for around twenty dollars that are fine for dovetailing, inlay, and so on. I use the standard model German jeweler's saw frames for dovetails and have used the deep throat fretsaws such as Joel sells for marquetry. Had not the OP specified Knew Concepts, these are the saws I would've recommended.
If one doesn't have a swivel saw or has a too-shallow frame depth and actually has trouble making the turn at the bottom of the kerf, an old trick is to hold a match to each end of the blade to quickly anneal them, then twist the ends 90° to ease execution of the crosscuts.
Woodworking demands little from a fret saw frame. When using jeweler's saws to cut very soft and very hard metals, it's altogether different story. A Knew Concepts saw frame can significantly lower blade attrition, saving considerable changing time and cost for piercers, setters and fabricators. Pike brand Swiss-made platinum or Vallorbe blades can also improve tool steel cutting tasks on a Knew Concepts saw, whether hand or motor powered.
Joel's fret saws for woodworkers
