bowl kilns?
paul woelper
Hey does anyone know the best way to build a bowl kiln? I have a ice box (83cubic feet)Id like touse but not so sure where to go from here. Any ideas would be great! Thanks for your input. Paul
bowl kilns?
paul woelper
Re: bowl kilns?
del schisler
why don't you post this over on the turnning section of the site? go up messageboards and open up and select turning and post their may be some one can help their also ?
Re: bowl kilns?
83 cubic feet or 8.3 cubit feet?
Easiest way.
Put a shielded light fixture in the bottom. Make sure the light can't shine on the wood. Use a 40 watt or similar incandescent bulb. You'll have to drill through the side for the cord. Seal the hole with caulk (or not).
I would put several more holes in the freezer. One hole near the bottom and one hole near the top (about 1" or so). Get some small metal plates and mount them near the holes. The idea is that you can control the size of the openings at the top and bottom to regulate air flow. You may want to have a couple of holes. I would also have another hole near the top for a thermometer lead. That way you can monitor the temperature.
If you put the light on a dimmer control, you can vary the intensity. If the light bulb is giving you enough heat, change to a bigger bulb.
I was REALLY surprised at how warm it gets. I've gotten temperatures on the order of 120 F inside my freezer.
Re: bowl kilns?
Don in Central Illinois
I'm looking for a dish washer. Tear out the sprayer and the heating element. Install a shop light. Drill a small hole in door for a thermometer ( dial ) to check on temp. Air fkow for hot air already installed.
