finishing nightmare!
eliot d
I am working on a table top of very beautifully figured cherry. I sanded to 180 and then used hand scrapers to get a really nice surface on it and followed up first with Velvet Oil, to bring out the figure, and then a coat of spar varnish, because it will be a vanity top in a bathroom. I let the oil dry over night and the next day applied the first coat of varnish. Tonight I started to sand the finish with 220 -- AND THEN THE NIGHTMARE STARTED! Everything turned a kind of spotty, streaky, white. It was a real mess! I had to hand scrape it all off and start over. (The stuff on the hand scraper looked like fine cheese particles.) It now has a coat of Velvet Oil again, and that's where I left it tonight. Perhaps I should have listed to some of you who suggested polyurathane. But I had the spar varnish and have used it successfully mixed with oil and solvent on turnings. My theory is that I didn't let the spar varnish dry sufficiently, but I really don't know. For the last table top I did, I used multiple coats of Waterlox with fine sanding between all coats except the last one. That worked perfectly. What do you all think went wrong here. Please help!
