Aw Chucks, -- Dirty Collets
George Colonel's Workshop-Havertown PA
Good Afternoon Friends,
Recently a couple of my P+C routers with 1/2" collets began to argue with my depth settings. These are the two which I use almost daily: a big 7518 in my router table, and my D-handled 690. I figured to finally follow Carol's advice and replace the collets. The P+C/DeWalt factory repair center is about 12 miles away and the machines now sport new collets. (at ridiculous cost). As I swapped out the old for the new ones, I realized just how dirty the old ones were, and used Simple Green and paper towels to scrub them clean.. Then I peered into the collet mount and saw a wood dust cake covering the bottom of the casting and portions of the inside walls. I attacked these also, and then examined my 690 standard base and plunge routers. In each case, the collets and shaft ends were filthy.
How often do you clean your collets? I saved the old ones. They looked pretty fine after the Simple Green.
George
Re: Aw Chucks, -- Dirty Collets
I actually clean my hand held routers fairly often - probably after every 3rd or 4th use. I even apply a little lube on the outside of taper where the collet wedges in the router. However you did get me thinking, the only time I clean the router table router is when I change collet size, and I haven't done that for a long time.
Guess I better look at it next time I change a bit. I did buy some extra collets a few years ago when they were on a clearance sale at either Rockler or WoodCraft for about 1/2 price.
Carol
Well, George, I blow out the socket and collet every time I change a bit. Especially if the router is in a table. I just got a router lift for big honker 7518, so I will need to be more diligent that when I take the router out of the table.
I have a horror story from my teaching days about a filthy collet, socket and scored shank that met up with a brand new pair of Levi's - under power. But I will spare you all the gory details.
Lesson: Dirty collets do NOT hold bits reliably.
Colonel,
All good soldiers know to keep their rifle clean and their collets clean. Now drop and give me 20!!!! :D
T.
Jason Waters
I think putting them in a jar overnight with something like Hoppe's gun cleaning solvent would loosen the crud, and you could brush with a toothbrush (don't reuse for teeth) and the then dry would work well.
Joseph Mulherin
Along with that idea how about using some denture cleaning tablets in the solvent. I should loosen and clean the collets like new.
AZ in Colorado Springs
I blow out the sawdust every time I remove a bit. Every third or fourth time, I wipe both the collet and the cavity in the shaft with a q-tip dipped in paint thinner. I learned my lesson about cleaning collets when a bit got stuck in the collet and I broke it using pliers to remove it.
David Barnett
Ring around the collet! Ring around the collet!
David Barnett
Those dirty rings!
Try Wisk!
