Re: best finish for black and white ebony
Steve Schoene
Watco and Waterlox are entirely different kinds of finish, and are themselves both different from the Tru-Oil. Watco is a mixture of oil and varnish--not a large solids content, and if you apply it you MUST wipe off all the excess or you will have a really soft film on the surface. Waterlox is varnish, not a mix of oil and varnish. Yes, tung oil is one ingredient in the varnish, but it has been cooked with resins (phenolic and a bit of pine rosin) to chemically transform it into the varnish. You can build a film on the surface with varnish if you want. Tru-Oil is linseed oil, but linseed oil that has been industrially polymerized. The polymerization allows it to cure much harder than boiled linseed oil would if cured in air. It lets the Tru-Oil cure much faster than boiled linseed and makes the cured result hard enough that it can be allowed to build a bit of a film on the surface.
Note that ALL of the oil based varnish products will impart an amber tone to the white portion, some more than others, and some will yellow significantly over time. A diffent approach entirely is needed if you want to end up with white white.
I do have a question. What is the "white ebony" to which you refer?
