Lesson learned on DW735 planer - sawdust inside
I was having problems with sawdust collecting inside my DW735.
The fan housing consists of two pieces around the impeller blade. There is a small double "lip" on the fan housing on the piece not next to the motor.
Eventually, the inner lip can wear away due to lots of planing. It doesn't appear damaged, because of the smoothing effects of the abrasive wood chips.
The double lip is fairly important. Without a double lip, you have lots of sawdust inside.
Re: Lesson learned on DW735 planer - sawdust inside
Thanks I will try to check mine periodically.
Good To Know........
Dave's Not Here
I'll keep an eye on mine.
Bob
Bob
So is that a replaceable part? Mines been doing that for a while and I couldn't tell what was going on. About to take it to the repair shop but if I can do it myself all the better.
Bob
Re: Lesson learned on DW735 planer - sawdust insid *LINK*
Order a fan housing. You can sort of see it in one of the schematics on detail 2.
The part number is 5140103-077.
Of course the shipping is a bit much and the price isn't very good. But hey - less sawdust inside.
ServiceNet Dewalt
Charlie Lenz
I'm going to guess that this is only a problem if your not useing a Dust Collector ?
It doesn't matter
My cyclone still has a lot of CFM. The constant abrasion of the wood particles over the plastic over time eventually wear the plastic away. It is only a small little lip - but it does wear away.
But realistically - I've planed quite a bit with the DW735 over the years. So quite a bit of wood chips and sawdust has worn away the plastic.
Now if I were to design it, I would probably make the fan housing out of a tougher plastic or metal.
Re: I'm not real familiar with the DW735...
Charlie Lenz
Except that I know it's been out there for a few years, and seems to be a fairly popular Planer. What puzzles me is that I don't know of any other Planer that has a blower to blow out the chips, I'm guessing that there must be some kind of accessory dust bag for it. But if I was hooking up a Dust Collector to the Planer, I'd just asoon not even have the blower in the way. My experience with the Dust Hood that I built for a Ryobi Thickness Planer was that it got everything, I'm expecting to get the same results also on a Delta DC-33 Thickness Planer. Out of curiosity, what Dust Collector are you useing now ? Is it portable , or hooked up to a ducted system ? Do you have any sharp bends in the hose or ducting ? And if you have a ducted system, how large is it ?
I have an Oneida cyclone.
It gets the chips out of my jointer, cabinet saw and planer - same hose. I've got a 4" hose that goes to a 5" drop. I just vary which tool I hook up.
My band saw, lathe, router table and work bench are also hooked up.
No kinks in the hoses. As I said, it is just wear. The small little plastic lip (maybe 1 mm or so) has just worn away.
I wouldn't have minded a straight adapter that goes from the cutterhead to the outside - I've easily got enough CFM for that.
Bob
Bob
Thanks for the info.
Bob
Bob
Bob
Jl, I finally pulled the housing off mine and you are spot on, except mine has worn through the lip and the outer housing so there are a couple decent size holes in the joint between the two parts. Funny though, it's worn so smooth I wouldn't have thought it was wear unless you'd mentioned it, thanks. Turns out both pieces need replacing and it might not hurt to replace the fan as well as it seems pretty worn. Any thoughts on how to remove the fan to get at the inner half of the fan housing? Looks like there is a special attachment that can lock onto the pulley end of the motor to hold it while the fan is unscrewed.
Bob
Bob, this is a several step process.
After you remove the top of the DW735 and the "blade shroud", go ahead and unscrew the outer portion of the fan housing and remove the clips.
Hold the "fan" securely and take off the nut and washer. Remove the fan.
Using a Phillips head screw driver (short one), remove the three screws that hold the inner portion of the fan housing. Don't lose the screws.
You will have to take the clips from the inner portion of the fan housing and transfer them to the new one. You will have to take the spring and moveable post from the outer portion of the fan housing and transfer to the new one.
Reassemble in reverse.
The only "tricky" part is holding the fan blade securely. I just held on. I suppose you could wedge it or hold it with a pliers. The nylon washer nut does hold on quite well - but it will come off of the shaft - eventually.
Need a favor, Bob
Could you either correct your e-mail address (in "Set Preferences") or uncheck the "email me" box at the bottom of your next message. Otherwise the notices all bounce back to me.
Thanks,
Ellis Walentine, Host
Bob
Re: Need a favor, Bob
Bob
Oops, sorry about that Ellis.
Bob
Bob
Bob
JL,
Thanks for the full instructions, very helpful. Parts are on order.
Bob
