Ellis' kitchen
Ellis' kitchen
Ellis' kitchen
Carol
Hey, Ellis,
Saw where you commented on finishing your bird's eye counter top. Did I miss the shop shot? :)
Re: Ellis' kitchen
Shucks
Here I was trying to keep my new kitchen quiet. Actually, I've held off taking quality photos because I'm waiting for the adjacent floors to be refinished before I install the finish cork floor in the kitchen space.
I'm realizing that this kitchen is so small that it might be hard for people to appreciate the work that went into this renovation. You really had to see the old 50s vintage kitchen we ripped out to make the new one. Not to mention the ancient and shoddy wiring and plumbing, old plaster walls, built-in-place cabinets, and all the other nasty stuff. Well, Carol, you might recall what an eyesore it was.
Now we have loads of light, tasteful (IMHO) tile backsplashes, nice cherry cabinets that blend in with the old flavor of the house, and organized storage space.
If anyone would like, I can put together a little shop shot. I tend to soft-pedal my own projects. Mea culpa.
Cheers,
PS, here's a teaser. Pardon the Vantek sub floor...
Re: Ellis' kitchen
Re: Shucks
Bob Entwisle in NJ
Ellis,
Beautiful!
And count me as one vote FOR a detailed (before and after) "shop shot's" of the project.!
Bob in NJ
Re: Ellis' kitchen
Re: I can certainly relate...
Charlie Lenz
Our home was built in 1917. The previous owner retired from Sears as an installer and did a few things that he should of known better. Our kitchen is small too and the wife calls it a one butt kitchen. Anyway, nice job so far, I'll be sure NOT to show her, thats another project that I've been trying to hold off on after doing it once 20 years ago.
Re: Ellis' kitchen
Re: Shucks
Ron Goldman
Coming along nicely.
Re: Ellis' kitchen
Re: Shucks - WOWZA!
Carol
I DO remember what it looked like. An amazing transformation. Bet Candy loves it.
Re: Ellis' kitchen
Progress!
Pan right? ;)
Re: Ellis' kitchen
Beautiful!
Re: Ellis' kitchen
Re: Very nice - beautiful job
I love that cherry. Nice proportions, lots of storage. Yeah, I would like to see more shots of that kitchen. I really need to redo ours, but I've been too lazy to do much lately. I do know what its like to work in an old house. Mine was built in the late 1800's - I've replaced a lot of windows, doors, wiring, plumbing etc over the years. Every job has a least a couple of "what the H---'s" found before its done.
Re: Ellis' kitchen
You're Lucky, Larry
Mine was built in the Mid-80's [the Nineteen80's]. In modeling both the bathrooms, the kitchen, replumbing the entire supply system, and r/r the HVAC, everywhere I went I was running into "WTF!!'s" but not a single "What the H..?" :D
ps: Of course we did find partial explanations when the rock came off the walls revealing the roaches and Old Milwaukee cans in repose on the foot plates. ;)
Re: Ellis' kitchen
Simply outstanding Ellis!
Stuart Hough
Gorgeous work! My one question is how you sealed the counter-top to protect it against the inevitable water and damp dish towels?
Re: Ellis' kitchen
Why did I look???
Darn it....I peeked. I hope to re-face our cabinets and I knew that if I looked I would see a high bar set. Curses!! ;-)
T.
Re: Ellis' kitchen
Re: Shucks
Dave Bair, Eaton Rapids, MI
I DO know how much work your kitchen involves; I took two years to finish mine. I didn't have quite as much other renovation, either. I see very nice, furniture-grade construction there. Good job.
Re: Ellis' kitchen
Great look, Ellis
Yonak
Is that a squirrel on your bird feeder ? ..Caught in the act in perpetuity.
Re: Ellis' kitchen
Finishes
Yeah, I agonized a bit about how to protect a maple counter top, and decided on four coats of spar urethane (three gloss followed by 1 semi gloss, sanded lightly between coats). It worked out better than I thought. I also laid a good gasket of silicone between the top and the backsplash tiles to keep water from leaching in there, and I installed the sink with a whole tube of silicone. I also prefinished the sink cutout with West System epoxy to rule out any water making it into endgrain there. I learned that lesson on my first major kitchen job in '75 or so.
So far, the urethane is holding up well to moisture, abrasion and abuse, although we are careful to use cutting boards these days.
Re: Ellis' kitchen
Finish
"So far, the urethane is holding up well to moisture, abrasion and abuse, although we are careful to use cutting boards these days.
And hot pads and trivets! ;)
m
Re: Ellis' kitchen
Re: Finishes
Steve Schoene
Strangely enough, spar varnish is generally less moisture resistant than interior varnishes. (The primary design parameter for spar is flexibility, followed by UV resistance.) I'd choose Waterlox for most moisture resistant and very tough varnish. Since I doubt you walk on it with shoes on, the urethane's abrasion resistance isn't of value. Behlen Rockhard would be my second choice.
Re: Ellis' kitchen
Re: Shucks
Jason Waters
I don't want to let my wife see this, I will be busy!! Just beautiful. Want to come to FL for a month and rebuild mine????
It just "pops". Lots of hard work in there.
Re: Ellis' kitchen
Reality check
I don't doubt your information about moisture resistance, Steve, but it's neither here nor there, as it is plenty moisture resistant enough for the task at hand. After all, spars required moisture resistance as well as flexibility.
Regarding urethane and Waterlox, first, I expressly do need the kind of abrasion resistance that a floor does, because we have stoneware plates and bowls that are murder on softer finishes like Waterlox. I once did an upscale dining room for a customer and finished everything with Waterlox. I ended up returning three months later to topcoat with urethane, after the customers had totally scratched the sideboard surface with their dinnerware.
Re: Ellis' kitchen
Ditto
Did my daughter's kitchen island with Waterlox on the top with the view that it would get scratched, but be easy to renew and rub out. Didn't take too long for something to react with the soft film, pealing away a contact ring. Resanded and then redone with Enduro Clear Poly with added crosslinker; been fine ever since. Like and use Waterlox a lot, but I won't use it for a furniture wear surface.
Re: Ellis' kitchen
Almost ditto
I do use Waterlox on tabletops as well as other furniture parts, but it is with the understanding that it will develop a nice worn patina over time, and the more coats you build, the longer it takes to wear down the finish. But for really high wear areas like a countertop or credenza, I like the added abrasion resistance of urethane. It's going to be harder to refinish down the line, but it'll hold up better in the meantime.
