We value your privacy.
I did most of the work on a vanity top. It's about 2 x 4 feet x 3/4 inch select cherry. Naturally, there will be moisture and water on it when installed. What do you recommend for a finish? I plan to start with some oil to bring out the figure.
... would be for oil-based polyurethane. I just finished our birds-eye maple kitchen counters with four coats of Helmsman "spar polyurethane" -- three coats of gloss and one coat of semi-gloss. It built nicely, dried fast, and gives a nice smooth abrasion-resistant surface.
I am most probably misinformed, but I had been told years ago to avoid "Spar" Varnish or finishes for interior use as the term Spar indicated it was formulated for outdoor use - the term Spar indicated it was for boats and other exterior uses and was a softer more flexible finish meant for use where it needed to expand and contract due to being exposed to high and low humidity (Rain and Sun). I can't remember the person that told me that but i believe it was a paint dealer. They said the finishes for interior coating was much harder and more durable in indoor use. Of course this may have been before the Urethane's and Polyurethanes were even developed. I'm sure you know what finishes are best Ellis - just like to know what the "Spar" does indicate now?
They call this stuff "spar urethane", which says to me that it contains a balance of the flexible resins that spar refers to, as well as urethane resins to impart abrasion resistance. The can is labeles "interior/exterior" applications. I'm really quite satisfied with it.
Old fashioned spar varnish is good stuff, too, and as far as I know, there's no downside to using it inside, where it is subjected to less strenuous conditions than boat decks and such. The only downside is that it isn't rock hard like urethane.
I should try to get Michael Dresdner to stop by and straighten out this explanation, but it works for me.
The primary property of spar varnish was to have a high resistance to UV degradation - as boat spars are always out in the sun. The early ones were phenyl formaldehyde resin based - like the "original" plastic, bakelite.
Nowadays the resins can be formulated with UV inhibitors, so different formulas are used, and the old resins are too expensive.
I have had success in using a urethane floorfinish, intended for hard use areas, on my wood countertops. Two years in use now, and holding up very well.
I once met a very well-know woodturner at a big-deal show held only for gallery owners in New York( can't remember his name or how I got in there) , and he told me that he uses spar varnish on his turnings exclusively precisely because it has the flex you're talking about. Said that hundreds of years from now his finishes would be fine ; whereas the others would craze because they are do brittle. And, indeed, some turners mix up spar varnish, oil, and solvent for their finishing.
