OT - installing sod
OT - installing sod
OT - installing sod
Howard In Toronto
Hi all -
I had three dead Ausatrian pines removed from my front lawn this past winter.
They're out front now grinding the stumps (now, THAT'S an impressive machine!) and will level the earth for the sod. But I've never done sod before. Any advice re installation, merging seams, watering and support, etc?
Thanks.
Howard
Re: OT - installing sod
jp
You mean other than green side up?
From what I recall from my sod laying/landscaping days, the sod was cut so that 2 of the edges had a bevel. We made sure to overlap the bevels as much as possible. Also, like drywall, we tried to stagger the seams. For hillsides we also had some U shaped pins that we'd put in to keep the sod from sliding down the hill. Key part is to keep it watered and wet until the roots take hold. No matter how you lay it, however, it'll pretty much all look the same 1-2 years from now.
Good Luck,
JP, who, after 25 years, still considers the day he sodded a 2.5 acre yard in the rain one of his most miserable experiences.
J Barrett Irby
Site preparation is just as important under sod as it is for seed. you want the soil under the sod to be firm and free of weeds with the surface roughed up to allow it to root easily. You might want to remove much of the ground up roots and woody debris as possible. Wood decomposing in the soil sucks up nitrogen much more aggressively that the grass and will rob it of nitrogen. So smooth it out and compact it so it won't settle and put the sod down green side up. Keep it watered.
Chuck Bjorgen
Agree with those to say to remove as many of the roots and wood chips from stump grinding because of the nitrogen loss to decomposition. Soil prep also important. Maybe rent a tiller.
My house was built in 1965 and we sodded the complete yard the following year when the price was .23 per roll of sod. When the sod truck came, we'd put a case of beer near the pile. Got all the help we ever needed.
Green side up is good avice
Howard In Toronto
Thank you for bringing me right back to the fundamentals!
And thanks for the idea of staggering the seams - that's a great idea.
Howard
Ken Oakley
here in Florida we hire a crew of Mexicans-- They are the best at it.
Nitrogen
Tom Dunlap
There is a bit of nitrogen 'loss' in the soil while the shreddings compost. That's just temporary and it is actually there but unavailable to the turf until the woody bits are composted. Then through the magic of compound interest there will actually be more nitrogen available later on.
If you're really concerned about nitrogen loss just turn in a scoop or eleven of lawn fertilizer. Let it compost. In time the area will be greener than the rest of the yard.
YOu're going to end up with a mound of shreddings. You'll find that one side of the mound is more soil than shreddings. Go to the other side and get rid of the extra shavings. Use them for mulch rings around your trees. They'll like that immensely and it will be so much easier to mow around the trees. Don't pile the mulch against the trunk though...think donuts not volcanos!
Tom
Don't walk on it
I've never installed it, but I still have vivid memories of living in a townhouse complex, brand-new, where they'd installed it. It took at least a month* before it rooted into the ground; before that, if you walked on it, it was like walking on a soggy carpet. The sod would squish, the seams would open up; it would then look horrible.
*Can't remember more exactly; our now-40-year-old wasn't yet born, although his delivery date wasn't far away then.
I remember once
Mike Farinella
many years ago I helped my neighbor lay sod. He had watered it so much that is was like walking on a water bed. It turned out OK.
Many years ago in Iceland
Dustmaker Mike
a friend and I where watching a few workers putting down sod by the barracks my friend started to laugh at them because they had been putting the light brown side up, so he told them the green side goes up. The person putting the sod down stopped and looked at us smiled and turned the piece over. Seems both sides happened to be brown at the time the only difference was one side was a little lighter brown then the other.
Jim Rahbe, Bedford Texas
Re: That was Icelandic Cod, not Sod.
Mike,
I spent 12 wonderful months in Iceland in 1967. I don’t remember much sod, just volcanic rock and no trees. Since you mentioned barracks, I assume you were in the service. What branch and what did you do? I was in the USAF, stationed at Keflavick NAS, working on the old F102. We may have stayed in the same barracks..
I always tell people that I’ve been colder here in Texas than I ever was in Iceland. Sounds counterintuitive, but true.
Jim R.
