Repairing old finish?
The altar at Good Shepherd has some "problems". No, I don't know what the finish is.
Evidently the altar guild chair decided to "steam" the linens - while they were on the altar. Anyway - there are some "cloudy" spots in the finish. Sort of hazy in a couple of area. I'm suspecting water under the finish of course.
What are some good ways to test? What are good ways to deal with the haze?
TIA
Re: Repairing old finish?
Carol
How old is the altar? If very old, likely it is varnish or shellac. Try lightly padding on mineral spirits or paint thinner. For lacquer, try lacquer thinner.
I've run into this in old church furniture as well. Don't pad too hard and use a lint free product. I use old shoulder pads that are synthetic over some sort of padding. Old nylons stuffed with a pad of old tee shirt should work.
Lee Schierer McKean, PA
Try this before the padding with solvents. If it is trapped moisture, take a dry linen towel, fold it so it is about 4 layers thick. Take an iron that does not have any steam and insure eh steam is off. Put it on the linen setting. When the iron is hot. Place the folded towel over the hazy spot and iron it. Get the towel good and hot, keep the iron moving and don't scorch the towel. Lift the towel periodically and inspect the finish. If the cloudiness is gone you're done. This can be repeated if needed to get any remaining areas.
Lee
JMOHNIKE
I have used fingernail polish remover. Apply a small amount to the tip of your finger, and rub, gently, the haze. Don't over do it you just want to soften, not lift the finish. Let dry and repeat. In some cases it will not completly remove the haze, but often times it will reduce it enough so that it is not noticeable. Better than a full strip and refinish.
