Epoxy Mirror Coat leveling Fix??
Alan Young
Alan Young
I made a couple of chess boards last year and applied a Mirror Coat finish to the second board.
It worked so well that when I made another board this month I used it again. The first layer leveled perfectly. I added a second layer but it did not level well at all. I don't want to put a third coat on and have it add to the leveling problem. Can I sand this layer back and then add another coat?
-Alan
Re: Epoxy Mirror Coat leveling Fix??
del schisler
sure you can sand. sound's like you didn't have enough of the mix and it was thin?? I have poured 100's of the cypress clock blanks yrs ago . Most of the time 1 pour is enough what happen with the first pour ? It won't look any thicker with 2 or 3 coats > Make sure the blank is level also. Pour enough so that it run's off the ends. Than sand the nub's off when it is set . Over nite is enough to harden. The expoxy is great stuff if a big dust spot or a bug of some sort get in after you are done than the next day just sand it out and do another pour and it will look like nothing ever happened.
Yes
You can, but you want to be careful to get to at least 600 grit and do the final "rub" in one direction. Then clean the surface very well to remove any grit. Reason being here that there will be a refraction surface between the layers that may be visible with angled light, so the single direction of the scratch pattern will minimize the effect.
In this application, even though Mirror Coat is a "thin" resin, you can thin it a bit more with no more than 5% denatured alcohol. Mix the resin and hardener first, than add the alk. If you normally use a flame to release the air bubbles, switch to a hair drier instead; don't want the alk to flash. :\
BTW, do not add alcohol to thicker pours because thick sections get warm/hot enough to boil the alcohol resulting in a cured resin sponge-like material, a/k/a A Mess. ;)
