Making verneer
Making verneer
Making verneer
mjonesrdg
I want to slice 3, (maybe I'll get 4) i/4" flitches from a maple burl cap. I have a Jet 18" band saw, and a 1 1/4" wide blade, and I think that I know how to support the burl in a carriage/sled.
My Questions: I will want to plane the flitches to <1/8". I have a Rigid bench top thickness planer. Can these flitches go through the planer without breaking? Would I be advised to put them on top of another support board...like a piece of plywood? If yes, would I need to do something to keep the flitch adhered to the support board? It yes, how would you advise doing this? And finally, if I want to plane a board that is less than the recommended 12" in lenght, could I get away with it if it was similarly placed on a support board?
Thanks for any thought that you might give to these questions.
Mike Jones in Redding, CA.
Re: Making verneer
Re: Making verneer
Keith Newton
I would bet that the chances of your planer eating your unbonded veneer is over 95%. You can buy burl veneer, better and cheaper than you can make your own, if you consider your time is worth anything.
Re: Making verneer
Re: Making verneer
Chuck in Mtl.
i am inclined to agree with the other poster that the planer will make a mess of your thinly sliced burl. that said you would need to take extremely thin cuts, 1/64 or less and have the flltch well supported underneath. If there was some way to temporarily attach the flitch to the carrier so it would not move...don't know.
Re: Making verneer
Re: Making verneer
Don Orr
I'd be inclined to find someone with some kind of wide drum sander if you don't have one of your own. A Powermatic(Jet) 1632 would do a nice job and you can send short pieces through them easily. I've done pieces as small as 6" in mine. I'd be very hesitant to use a planer in this situation. You should be able to double-side tape your pieces to a backing board to get them thin enough, but a drum sander can usually get down to 1/8" without one.
Good luck and feel free to show us what you're working on.
Re: Making verneer
Couple things...
First, I agree with Keith that you are likely to have some blow-ups if you try to plane these slices. Don's suggestion of using a thicknessing sander is the best way to do it.
This said, a lunchbox-type planer will actually do a pretty good job of planing thin stock, with or without a sled under it, depending on the grain slope and the wood species. Some woods plane nicely and others are too brittle.
Re: Making verneer
Re: Making verneer
Jesse Cloud
I agree with all the above. And here's a couple more things...
Whether you use a planer or a drum sander, use a backer board. Run the board through the planer marking direction and mark a registration line on both the planer and the board so you can put it back in at exactly the same place.
The reason behind this is that planer blades and sander drums are almost never perfectly parallel to the table, so one side of the workpiece may be planed ever so slightly higher than the other. For most applications the difference is trivial, but if you intend to put one piece of veneer next to another, it can cause trouble.
I think the sander is the better option, but if you go with the planer, make sure your knives are sharp. There is a glycerin treatment that will soften the veneer and make it a little more pliable - increasing your chances of running without a blowout.
Re: Making verneer
Re: Making verneer
PaulSV
I did the same thing when making a cigar box. I planed the board that I was cutting the veneer from, then cut off a slice of veneer just under 1/4" Planed again, sliced another one. In this way I ended up with 4 veneer slices, each of which had one planed side. I then glued the veneer to the substrate on one side, making it 4 inches longer than the finished piece, and gluing the planed side to the substrate. I then ran the veneered side of the glued up panel through the surface planer. Next, I glued up the veneer to the other side, and ran that through the planer, and cut the panel to final size. (The extra 4 inches was to take up any planer snipe.) Kind of convoluted, and requires some planning, but it gets the job done.
Re: Making verneer
Re: Making verneer
Dave Bair, Eaton Rapids, MI
I have used a layer of double-sided carpet tape to hold down thin stock. You may have to remove it (the tape) with mineral spirits or alcohol since the thin stock may not stay in one piece if you just pull it off.
Re: Making verneer
Re: Making verneer
Dick Coers
Would you run <1/8" end grain boards through a planer? Same reason you would not run thin burl veneer. It will blow up, BIG TIME! You can do the resawing like they do with engineered flooring. Glue a sandwich together of two substrates onto a thicker piece of burl in the middle. When dry, resaw the burl down the center, and you have two burl veneer covered pieces. Make sure to have backer veneer on the substrate for balanced construction.
Re: Making verneer
lunch box planer into a sander
Chuck in Mtl.
i wonder if it possible to convert a lunchbox planer into a sander? Could the sandpaper somehow be adapted to it?
Re: Making verneer
Re: lunch box planer into a sander
Dick Coers
Probably way too much drum speed, too much friction on the metal table for feeding well, and small dia drum would make for a horrible combination. Grizzly sells something that looks like a lunch box sander.
Re: Making verneer
Thank you, guys!
mjonesrdg
Thank you, guys! I'll use your recommendations and give it a go!
Re: Making verneer
Re: Thank you, guys!
jim in west central mo.
A few days late in reply but I do have direct experience. Don't try the planner! You should consider purchasing a "woodslicer Blade" from Highland Hardware. Well worth the price and the results are amazing.
Then run your pieces thru a thickness sander ie, 16-32 jet. I typically run down to 1/32" with my set-up using no backer board. By the way, correctly set-up you would have minimal sanding following the woodslicer blade, something you could do by hand.
