OT: Best Homeowner Tile Saw
Stuart Johnson
I'm starting a tile project that will have many cuts. Most will be straight but one area will be angled. What is a good tile saw for home use? Like so many things online the price range seems to run from $70 to thousands with reviews on any given one ranging from garbage to not enough stars available. At the speed I work rental is not a good option.
Re: OT: Best Homeowner Tile Saw
Jason Roehl in Lafayette, IN
I bought one of the $70 no-name wet saws at Menard's for a couple small tile jobs. There's no question it's cheaply made, but it worked--and I was cutting porcelain tile. You just wouldn't want to leave any of the cut edge exposed--between the diamond blade and the vibration of the saw, the cut edges will chip a little (tiny chips).
However, if you want to greatly speed up your work, get a score-and-snap jig. You can have it right next to where you're working, without having to run outside where the wet saw is set up (they're messy). The scoring jigs don't make a mess at all, which is why it can be right next to you when you're laying the tile.
Jason
About 4 or 5 years ago I laid porcelain tile on my front porch. I purchased a real cheap tile saw on sale from Harbor Freight thinking it might work for the one job. I also purchased an extra diamond blade erroneously believing the blade would wear out quickly. It did the job with no problems although the diamond blade did make fairly rough cuts - not a real issue since most of the cuts were under the final trim. About a year ago we remodeled one bath room - installing a walk in tub. We put natural Quartz tile on the floor. I pulled out the HF saw and it again did everything we needed. I am still on the first blade and it still doesn't show any major wear! I think I paid $39 for the saw and about $10 for the spare blade (plus shipping). Its back in storage until someone in the family needs it again. That saw does look very much like the $50 ~ $75 or so saws at Lowes and Menards.
Scott Greaves
I would echo the sentiments about the cheap tile saws. We bought one over ten years ago and have used it on at least four pretty major tiling projects, and it has done everything we needed it to do. And yes, we are still on the first blade.
Scott.
Dave Bair, Eaton Rapids, MI
While I have no brand-specific recommendations, my advice is to get one with a sliding table; try sliding a 12x12, rough-backed, porcelain tile across a metal table while managing to keep it square to the fence (even worse if you're making an angled cut).
I bought the cheap (maybe $70) wet tile saw from Home Depot and like the people above assumed it might make it through a single job. I've done three with it and as far as I know, its ready to do number four.
The first time I ran it I did not read the instructions (it a GUY thing, Right?) and did not install the over the blade guard. It slung water everywhere, even on the ceiling. Be sure to use the guard. Even it the guard, it still gets water one the surrounding area. Would not want to use it in a finished area.
They sell a more expensive or that appears to be a dry saw with what looks like a tiny portable circular saw that slides on bars. Have not used it, but can't imagine running it indoors. It would have to be dusty.
I have no trouble cutting to a line with the one I have. Its tile work, not marquetry.
Barry, I had to do a lot of "notching" and odd cuts when fitting around the porch posts (and some in the bathroom around pipes etc.) I used mine outside on a bench - I had to remove the guard to see where I was cutting. I didn't even try to stay dry, just cut it all and took a shower :>) - still using it that way although the guard and fence is stored with it - to me the fence is just about useless, I just marked the tile with a marker and sawed to the line.
Jason Waters
I have the cheap HF saw too, and worked just fine for me for the shower and bathroom floor. A lot of tile cuts. Becuase of the configuration
I used a professional MK when I did the whole house. I would have rather used the HF saw for some of the cuts. I suspect the blade was dull, it was a friends, and it should have done better.
I set the HF saw on the back concrete porch, worked out there, flushed out the water regularly, and used a dip bucket to prewet all the tile (everyone does that, right?) and rinse it. A lot of walking through the house, but I put down rosin paper on my path (everyone does that too, right?)
The only cut I did otherwise was for the shower stub, I cut the hole from the back with a 4" angle grinder blade, real tricky.
It was cheaper to pay $59 than to rent. It took me 3 days or 4 days to do mine.
Stew Pharis
I'd agree with Dave on the sliding table. You can find saws with sliding tables for around $300 and well worth it if you're dealing with big tiles. Otherwise, the little $100 ones work fine.
Re: OT: Best Homeowner Tile Saw Thanks
Stuart Johnson
Thanks for all the answers. It sounds like the low priced saws will pretty well do the trick and are certainly cheaper than renting.
woody
I got a used "Work Force" from Craig's List for $20.00. One of my jobs for it was making diagonal cuts on 12" tiles. I added extension tables on both ends made out of Luan 1/4" plywood. I scribed lines on the plywood to line up the tiles. Most woodworkers could make these small saws work. I did several hundred feet before the motor burned up. I removed the blade on another shaft and finished the job with a belt drive. My point is that the 7" blade is GOLD.
THE REAL BONUS:...I USE IT TO SHARPEN CARBIDE TOOLS. Woody Rhinehart
I made a jig
Dustmaker Mike
to hold the tile square to the blade while I was cutting 13 inch tiles. I also have the cheap HD saw. If the cut edges are going up against a carpet or some place that shows the snap jig is the way to go. For all the other cuts the wet saw is. The jig I made was a piece of ply wood butted up against the edge of the saw table with a straight edge clamped to it. I then made a saddle to go over the straight edge and had it set to make the 45 deg cuts. I had a lot of the same size cuts to make and it worked out like a champ.
Jim Dillon
Stuart,
Yet another vote for the cheap $70-100 tile saw. Mine is a Plasplug (sp?) brand and it has more than earned its keep. They are messy, so work outside, and wear safety goggles.
Jim
